Cessna pax vent replacements
Anyone have experience with a more modern replacement for the rear Cessna vents? Preferably something of the same diameter and screw pattern as the original so it can mount to the existing can. I see some options around online but reviews are mixed and some require more extensive modifications. I'm installing new vents for the crew seats, these vents are the only thing that feels cheap/dated in the cabin so I'd like to replace them for aesthetics and function.
- IMG_3489.jpeg (23.35 KiB) Viewed 1944 times
CParker offline
487
- Aircraft: 1979 TU206G
CParker, I replaced those old plastic vents in my 1977 C180 with Bonanza eye ball vents sourced from an aircraft recovery/salvage company 12 years ago. Not difficult, but you have to do a few modifications to make them work. If I recall, you need to engineer the outer rings from aluminum and drill holes for the screw pattern.
limerick offline
83
- Aircraft: Cessna 180 Skywagon
Fri Jun 14, 2024 11:11 am
Interested for the outcome on those
Good find!
- Retired
1679
Sat Jun 15, 2024 12:23 pm
Dims check out, it’s slightly smaller in ever dimension. I’m going to order one and see.
CParker offline
487
My solution for the vents was these from A/S.
https://www.aircraftspruce.com/catalog/ ... ilver2.phpI had to replace the vent tube due to tears and discovered that Cessna had 1 1/4” tube from the wing necked down to 1” tube to the vent which of course restricts the airflow. The new vents have a 1 1/2” inlet so my son 3d printed 1.25”-1.5” funnels to run 1.5” tube to the vents. He also printed the fixture to hold the vents and fit into the original brackets. It’s an improvement in every way. The airflow is outstanding! I’m an A&P and signed it off as a minor repair.
Kras offline
1
- Aircraft: Cessna 185 Skywagon
Tue Jul 02, 2024 10:31 am
@cparker. how did you make out with the vent from Spruce? I have the same plastic ones and wan to consider newer ones as well.
Cameron96 offline
47
- Aircraft: C206 Turbine
