Backcountry Pilot • Cessna secondary Seat Stop
16 posts • Page 1 of 1
Remember this kit Cessna was giving away free a few years ago? SEB07-5
On the reel installed in my airplane, AmSafe P/N 505590-403, the little plastic fitting that attaches the manual release cable has broken off. AmSafe won't repair it and instructed me to get a new assembly from Cessna, somewhere north of $600.
Anybody know of a source for replacement parts for this guy?
Frustrating...
Halestorm offline
Aircraft: C-182E Pponk
Re: Cessna secondary Seat Stop
Here’s a little photo of the offending item I purloined from a Cessna Flyer ArchivesImage
Halestorm offline
My son has a laser printer. Would a printed part be an owner supplied part?
Lack of simplicity is one of many reasons I passed on the inertia reel and bought two of these: https://www.aircraftspruce.com/catalog/pspages/loree_05-22220.php
YMMV
CAVU offline
It doesn’t answer your request Sam, but I like these a lot:
https://www.aircraftspruce.com/catalog/ ... ftstop.php
slow18 offline
You could try C&M Marine Aviation Services. That’s where we send other kinds of Amsafe inertia reels for repair, and they can replace most stuff.
Ross4289 offline
Aircraft: 185
Thanks for the ideas, I'll figure something out...
Halestorm offline
Halestorm wrote:Thanks for the ideas, I'll figure something out...
Let me know if you can't get it fixed, chances are good that I may have a reel around from a wreck.
The problem with those stops that go on a seat rail is they will inhibit egress if you are in a hurry, as in upside down in water. I suspect that's why Cessna developed the under seat reels....
My 180K has the double pin setup for the seat rails which I like. I also think the lap seatbelt buckle would work fine with one half attached to the seat and the other to the floor. Whole lot siimpler than this reel deal.
Mine just broke last week in the exact same spot. I guess that little plastic part has only so many cycles in its life. I have not pulled it apart yet. If anyone finds a part source or repair let me know. Thanks.
180driver offline
mtv wrote: The problem with those stops that go on a seat rail is they will inhibit egress if you are in a hurry, as in upside down in water. I suspect that's why Cessna developed the under seat reels....
A reel that won't release will inhibit egress just as bad or worse.
I like the cam-style seat locks that CAVU posted a link to, but they're kinda spendy.
I've got a pair of saf-t-stops, actually several of them-- besides seat stops,
I also use them for cargo rings on the front seat & BAS seat tracks.
CAVU wrote:Lack of simplicity is one of many reasons I passed on the inertia reel and bought two of these: https://www.aircraftspruce.com/catalog/pspages/loree_05-22220.php
YMMV
I use this product both pilot and copilot seats. Worth every penny. Very easy to use and install. The big red handle is easy to lock and unlock.
Josh
Dog is my Copilot offline
Aircraft: 1958 Cessna 180A
Worth a try... I would print it out of PETG.
https://www.printables.com/model/180371 ... or-housing
Sleddriver offline
The cam locks are the best, much easier to release then the Cessna system. In my 206 as bought the Cessna lock could not be unlocked prior to touch down in a forced landing. It takes two hands, one to release the lock and the other to simultaneously slide the seat back. Stupid in my opinion.
Its real easy to drop a hand to the release lever on the cam lock and release and slide it back it prior to landing. I put both the pilot and copilot locks on the inner seat rails so I can release both my self. I unlock them for the copilot/pass at normal shut down so they can get out too, very natural.
dar636 offline
Aircraft: Cessna A185F (sold)
Cessna P206E
dar636 wrote:I put both the pilot and copilot locks on the inner seat rails so I can release both my self. I unlock them for the copilot/pass at normal shut down so they can get out too, very natural.
Good idea about keeping them on the inner rails. I unlock both of mine and slide them all the back as soon as I'm established in cruise climb. It's a habit now. I should add that to the checklist, though.
CAVU offline
