Cessna SK185-27
Wed Jun 06, 2018 12:58 pm
I just installed the SK185-27 (jackscrew inspection panel) in an A185F. I am sending Zzz the PDF of the install instructions if anyone is interested. Hopefully he can add it to the database. Nice mod and very useful.
2339
- Aircraft: C180H / C170B
www.avthreads.com
2854
Bigrenna wrote:I just installed the SK185-27 (jackscrew inspection panel) in an A185F. I am sending Zzz the PDF of the install instructions if anyone is interested. Hopefully he can add it to the database. Nice mod and very useful.
Very nice! Thanks Bigrenna.
Do you have photos of the installation?
Is it just for inspection, or does this access point allow for complete removal of the jack screws without pulling the vertical and horizontal stabilizers?
Scolopax offline
1696
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 4aYqSexnZC
You can remove the jackscrews, but you wouldn’t be able to rig them, at least using the service manual method, as it requires measuring 4.37” between a drill rod thru both actuators and the base of the stab up-block.
jrc111 offline
347
- Aircraft: C180B
jrc111 wrote:You can remove the jackscrews, but you wouldn’t be able to rig them, at least using the service manual method, as it requires measuring 4.37” between a drill rod thru both actuators and the base of the stab up-block.
I think the '63 SM has a different procedure, done with the horizontal on.
5186
You are correct! The 1963 to 1977 SM’s, and maybe later (I don’t have any later SM’s) does describe such a procedure. Pretty challenging from below only, I suspect.
jrc111 offline
347
- Aircraft: C180B
You can rig through this panel fairly easily if you understand what the rigging guidance is trying to accomplish. Sometimes you need to read between the lines to figure out Cessna's end goal. In the case of rigging this trim system. you need to make sure that you are hitting the up (nose down) stop at with just a little (1-2 links) of chain travel left. If you've got that, the down (nose up) travel pretty much takes care of itself.
AEROPOD offline
479
What I found difficult was getting the links threaded correctly on the left actuator sprocket and the correct links between the two actuators without turning the sprocket while trying to get the chain guard secured in place:
https://backcountrypilot.org/community/ ... 9?start=40
jrc111 offline
347
- Aircraft: C180B
Flying Dave offline
210
- Aircraft: Aviat Husky
Where did you get the kit? I can't find one.
Eddie
lefoy84 offline
81
jrc111 offline
347
- Aircraft: C180B
Just talked to them. Textron has two scheduled for production in September. "TWO" YGBSM! Can't find anyone who has one in stock.
lefoy84 wrote:Where did you get the kit? I can't find one.
Eddie
lefoy84 offline
81
I think you forgot an F in that acronym, but that may be the former Marine in me!
jrc111 offline
347
- Aircraft: C180B
AK-HUNT offline
91
jrc111 wrote:https://cessnadirect.com/product-search/?brand=all&query=sk185-27
I contacted Yingling aviation today and spoke with Rebecca. She said the wait time from Cessna is 12 months. I brought up the idea that if there were several people interested in having this part made they may assign a higher priority and give a better price and get it done faster. Maybe there are enough of us interested to consider this.
Dog is my Copilot offline
433
- Aircraft: 1958 Cessna 180A
Ive got an old Univair price book from 2008, those kits were $145.
10534
