Backcountry Pilot • Cessna Tail AD
Cessna Tail AD
5 postsPage 1 of 1
Cessna Tail AD
It’s time to get serious about this tail ad. I have an appointment with Beegles in September, but the logistics of getting there and back are looking like a major pain. I got a reference for a guy up in the UP, which is difficult if he can’t do it while I wait. There’s no commercial service up there, as far as I can tell.
I also know of a guy in Pennsylvania and a possible in Arkansas. The best guy close to home doesn’t want to work on Cessnas. Or maybe he just doesn’t want to work with me!
It would be really great to find someone who’s seen the jack screws and trim system before, and who’s located in a place that’s easily accessible from Indianapolis.
Ideas?
StuBob offline
Aircraft: Cessna 185 Skywagon
Re: Cessna Tail AD
Richard Castle AI at Macon Airport, Missouri. [email protected] 660-415-6998. He has flown his own airplane to jobs for me.
Re: Cessna Tail AD
Kubick Aviation In Iron Mountain....100 north of Green Bay....Delta has flights...justbdi mine.....1956 182 aa part of annual ...added 3 1/2 hours.....906-779-5500....They have great avionics too....
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Re: Cessna Tail AD
StuBob wrote:...It would be really great to find someone who’s seen the jack screws and trim system before, and who’s located in a place that’s easily accessible from Indianapolis. Ideas?
Who do you do your annuals with?
it's always easier to have a mechanic on your home airport or at least nearby do your work.
If you run into a big downtime-inducing issue, you can just stick the airplane back in your hangar & wait.
Re: Cessna Tail AD
There is nothing complicated about the Tail AD - any decent mechanic can do it. It’s not just the hockey stick, and there have been a fair amount of people who have found issues when they’ve done the inspection. Some will say pulling the tail apart is not necessary - using a bore scope is all that is needed, I personally don’t subscribe to going that route. At least not for the first one. Take the hit - open it up and go through everything. When the SB came out and it was going through the recommendation for AD phase, I heard a lot about it being an over reaction and I got influenced by that.. I think the tide has turned on that sentiment as more and more folks found problems after doing the inspection, certainly more then most expected. Anywho I’ll step of the soapbox. Back to your original statement - I don’t think you need to hunt down a specialist - any competent mechanic can do it.
corefile offline
Aircraft: Cessna 180 - sold
5 postsPage 1 of 1
