Backcountry Pilot • Cessna tail slide testing
23 postsPage 2 of 21, 2
Re: Cessna tail slide testing
motoadve wrote:
G44 wrote:MotoDave,
Im not excited at all. And no, I did not buy the product. The device does indeed look like a good product for hard surface skin protection. Kudos to the guys making the product for their effort! This product protecting in the rocks is a stretch, the fact that your airplane did not suffer any surface damage is lucky in my opinion, if you keep doing it I can assure you that you will suffer damage back there. As to weight, I was just referring to what you said or listed in the video, I have no idea what it weighs. Im still trying to figure out the "lift enhancing feature". With this device any tail impact on the ground will still have potential bulkhead damage or over time cracking issues, no way around that unless there is some sort of impact absorbing device back there, such as a tailwheel. So, as calmly and as non excited as I can say it, intentionally dragging your tail thru the rocks with this device on or not and expecting no damage at some point in time is wishful thinking.
PS, I think your video making skills are superb, you fly your airplane very well.
Thanks Kurt , I did the dragging of the tail on the gravel bar on purpose once , that does not mean it will be a new landing or take off technique , because eventually yes tail section will definitely get damaged.
As I have done always I will continue to avoid having the tail contact the surface.
Keep a close eye on that tailbone bulkhead.
G44 wrote:
motoadve wrote:
G44 wrote:MotoDave,
Just got done with the 180 tail service bulletin. Not a small effort. Learned a lot while doing the work, especially what bends during a hard landing and what structure is prone to cracks from dragging my tail (with a wheel in the back) through rough surfaces. Kudos to your skill flying the airplane, that said I did cringe a little watching the tail run through rocks. Lots of expensive (and flight critical) parts back there that aren't trivial to get to or easy to inspect.
Product looks great and I compliment anyone stc'ing airplane parts. I'd hate to see damage to your plane for a product review for any of our sakes though.
BazzLow offline
Aircraft: 180H
Now that you mention this, I was seeing my firend's 170 at the same gravel bar , he landed on the looser bigger rocky area, the tailwheel was not liking it at all, jumping, bouncing, dragging rocks, I can see that can damage some structure if abused.
Mine was just that landing and take off, where the gravel was small, no damage at all , but I wont be repeating this (on purpose anyways), and will try to avoid the tail contact with the ground as I have always done .
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
