Luke Schiada, senior air safety investigator with the NTSB’s office of aviation safety, said Monday that after examining the crash site, it appeared that the plane’s rudder-control gust lock was still in place. A gust lock, which keeps the rudder stable when the plane is stationary, is usually removed before takeoff.
“The effect of that gust lock on the accident flight is something that will be analyzed later,” Schiada said. “At this point we’re still in the fact-gathering stage of the investigation.”
He added that investigators still don’t know the cause of the crash and that the rest of the investigation will determine what happened.
Papa Foxtrot wrote: When I saw this last night, my first thought was how do you manage to ball up a Champ bad enough to result in two fatal? Docile, slow and steel tube fuselage - doesn't get much safer.
hotrod150 wrote:Papa Foxtrot wrote: When I saw this last night, my first thought was how do you manage to ball up a Champ bad enough to result in two fatal? Docile, slow and steel tube fuselage - doesn't get much safer.
This comment reminded me of the old joke.........the Piper Cub is the safest plane in the world- it's just barely fast enogh to kill you. When you consider that you can die from a fall in the bathtub, any airplane goes high enough & fast enough to easily do you in.
Littlecub wrote:Only 9 registered??
Only 9 Champ accidents registered??
Help me here....
lc
scottf wrote:For those who have never flown a champ, I am assuming the gust lock is the clamp on variety that actually clamps on the rudder and not inside the cabin?
