Good afternoon everyone!
Can anyone tell me how difficult it would be to swap tires on a Pacer/Maule on a regular basis? Is it realistic?
Plane will be hangared at a Class D airport but will frequent the back country and fly in's. Any input?
TxAgfisher wrote:Thanks 8GCBC, it would be whole assemblies.
It will have either 26" Airstreaks if I buy the Pacer or 31" ABW on the Maule. I would probably run 8.50's on the Pacer for regular use or a 26" on/off pavement tire on the Maule.
TxAgfisher wrote:What is the easiest way to do it though? I've heard of guys clamping blocks to the gear among other things.
TxAgfisher wrote:It will have either 26" Airstreaks if I buy the Pacer...
TxAgfisher wrote:Good call Rob, it will be an appropriate 26" tire.
But yes, that was my question - how do you support the airplane to change tires if you do not have an airplane lift?
