patrol guy wrote:182 - I always thought my next hangar would be a wooden barn type floor, made out of rough sawed lumber. Ideally it would be easiest on a slope, so that you roll the plane in level and the backside drops down. As long as airplanes are all you put in it (no weight). Big tractors and trucks would not work.
That way air moves through the cracks and most likely less moisture then concrete. Stuff stored upstairs in bank barns, never seems to rust around here.
182 STOL driver wrote:Anyone know of "Cheap" way to do a hanger floor -about 40'x 50 ' ---??? I've looked into Cement -Delivered as $100.00 bucks a yard -with 3 inch slab that's $$$$$ .I'm looking at asphalt maybe less ?Or just a 20' x 20' slab in middle ???? For now I'm just renting the hanger (Private strip near where we live)-may buy it down the road . Any ideas ? Right now floor is dirt with carpet __ Thanks Bill Reid
bloomah wrote:heavey felt from the papermachine is great stuff.
Be carful not to cut the tubing when you saw cut the control joints. I like to keep the system pressurized while pouring and cutting that way I can see if I caused a leak. Jaerl wrote:Bill, Is it going to freeze? Lots of water? If you don't have either one of those to deal with you can get by with less. Concrete is the best and 3" isn't thick enough. Go at least 4". If you want something cheap and you have a steel mill close, use slag. 4120 if they have it. Look in the phone book for Heckett, they do a lot of slag recycling. It will pack so hard you need to jackhammer it out after it sits a few years. The ideal way is to put down the slag for a sub grade. Then pour concrete and you'll never have a problem with it.
Do not! use gravel!!! It dosen't compact. In your neck of the woods they have coleche. Could it be ground up and then recompacted? I know it's as hard as a rock and would probably make a good base. Might call a gravel pit nearby and talk to them about it. Just leave it low enough that you could add concrete later because that is the way to go. Call me if you want. I have been doing concrete for 35 years and I would be glad to help.
