Backcountry Pilot • Cherokee 180 Approach
31 postsPage 2 of 21, 2
Re: Cherokee 180 Approach
Nosedragger,
I hit send before I was done. Thanks for the very astute question.
Contact
I have over 30 hours in Cherokees and am quite comfortable in them. I just wanted to confirm that 80mph seemed like a great recipe for floating. I agree they do a bit better with a touch of power to give the tail a little more authority.
With all this talk on airspeeds for final, my best approaches and landings in the Citabria were the day the ASI quit on me. Just feeling the plane out I had some excellent greasers. I even had people come up to me after to compliment me (which is a very rare occurrence). They were shocked to learn I wasn't using an ASI.
PilotRPI offline
contactflying wrote:Nosedragger,
That is correct. By maintaining what appears to be a brisk walk, our airspeed will automatically be higher in a headwind and will automatically be lower in no wind and even lower yet in a tailwind.
If we are maintaining what appears to be a brisk walk in a 30 knot headwind, however, most pilots and all aircraft would want to take advantage of an even slower ground speed on touchdown. So we would use even a bit more elevator to slow both apparent rate and ground speed even more. Realize that the pitch attitude will still be less than in the no wind because the headwind is automatically slowing our ground speed. The airplane is feeling just fine with all that 30 knots extra kinetic energy of pressure airspeed over and under the wing so why not take advantage of the help?
There are some things we have to watch for, however, on this pleasantly slow and easy to control approach into the strong headwind component. First, we are very level so we will want to cut the power just before touchdown and flair a bit to protect the nose gear which hangs down lower than the mains. Also we want to guard against becoming so enamored with our slow, controlled approach that we allow the aircraft to drift backwards. Zero ground speed at touchdown is fine. -3 knots ground speed at touchdown is not fine. The apparent rate of closure approach, in a strong headwind, is like target fixation on a gun or rocket run. It just gets better and better and you have to snap out and say, "we need to finish this." Finally, we have to deal with gust spread, which usually accompanies a strong headwind component. We will have to move the throttle quickly and as much as necessary to get ahead of any shear or updraft or downdraft. We don't want to forfeit our very useful, for low ground speed on touchdown, flaps just because we have a headwind. I use full flaps on all approaches. When sinking fast, we need to put the throttle full in and then adjust. When rising fast, we need to pull the throttle full back and then adjust. In mild gusting we need to move, not adjust, the throttle as necessary to maintain the desired glide angle and desired rate of descent.
Downwind landings can get a little exciting. To get the same apparent brisk walk rate of closure, and the same ground speed, we would have to slow the airspeed more than our engine could handle in a 30 knot tailwind. However, crop dusters often set the auger truck up midway down a three thousand feet runway so ag planes can come from both ways to load dry material. Dry fertilizer will not weigh as much as a full liquid load and it is put out at hundreds of pounds per acre so there will be many takeoffs and landings. And the reason they are spreading instead of spraying is that the wind had gotten up. So how does the one landing downwind and then taking off upwind get it down in fifteen hundred feet in a ten to fifteen knot downwind? He will be using a lot of power to hold the very high pitch attitude necessary to slow the airplane down enough that he is approaching at what appears to be a brisk walk. And the loader up there doesn't want him to round out, hold off, float in low ground effect, and finally flair.
Thanks for the walk through. I picked up most of what you're laying down. You're on my list of people to go fly with someday.
I'm terrible at tailwind landings. Mostly because it's a good way to get shot around airports, so I never practice. I about blew an ILS approach on my checkride because I flew it to circling minimums with a 25 knot tailwind for the first time ever. It does make it easy to understand the pitch/power differences depending on what you're trying to maintain when you're wearing foggles.
Nosedragger offline
Nosedragger,
I have grandsons in Charlottesville, Va and Denver. We get to each place at least once per year. Do you ever go to Denver? We might get together there. I lost my medical and fouled up Light Sport so my wife won't let me have an airplane anymore. The argument that I wasn't always legal back in the day doesn't work at all with her. Fly for food? I'm desperate. I'll buy you lunch.
Contact
Contact
PM me if you go to Denver. I'm 31/2 hours out. We'll go to Laramie for a guaranteed wind event.
Nosedragger offline
I will.
mtv wrote:Here's one issue with these kinds of dpiscussions: When someone says "I use 80 on final (or on approach)", you should be asking two questions: First, as others have noted, are we talking knots or mph? Second, WHERE on final or on approach are you flying that speed? Are we talking 70 knots (or mph) on half mile final? Or at the threshold?
This is the first thing I thought as I finally read through this thread.
"Approach" can be a nebulous part of the landing phase, but short final is where I like to be established at a stable minimal-energy configuration. Up until that point-- turning base, dogleg, final, etc, I might be maneuvering at at a much higher speed just to get the hell there, but not so fast that it's too much effort to bleed off speed. Depends on the wind. Sometimes you have to honk it on with a lot of power just to make the fence, but those days it's easy to get rid of it.
Zzz,
Next time you're "honking it on with a lot of power," in a big wind, look at the GPS instead of the airspeed indicator and think about your apparent rate of closure.
Contact
I've had the Hershey bar 160 for a few years now and routinely fly my approaches at 80 MILES per hr. You can go a little slower if you're light and need to. 70 "over the fence" works if you're trying to get in short and not heavy. But... having said this, there's nothing better than taking the plane up, doing some stalls, and checking what YOUR airspeed indicates, then making the calculations others have posted on here.
Coming from the 170B, the Cherokee climbs better, descends better (??) but needs a little more speed on the takeoff and touchdown. If you're used to Cessnas, it takes a little getting used to. ( They sink like a savage if you get too slow).
If you're used to the Warrior /Archer. There's not as much difference. The long wing ones can be pulled off a little quicker. but in the air. Same.
I Run the Cherokee off the same grass strip that I ran the 170 ( 1800 ft.) and can handle similar loads. Remember that the piper holds another 15 gallons of fuel.
oldtech offline
Airspeed, Altitude, Brains. You need 2 of the 3!
The Oldtech
I have put about 25 hours on my 68 Cherokee and I try to hit 70 to 75 MPH on a relatively calm final, I'll come in at 80 MPH in more gusty/cross wind conditions
mnewb1 offline
I tend to come in at idle power, controlling the angle of descent with airspeed. If I need to steepen the angle, I add flaps. If full flaps aren't steep enough, I add in a slip. With full flaps plus a full slip, the Cherokee will get in pretty short.
Since in many of the planes I fly, the runway can't be seen on approach, I tend to look off to the side, even when in the Cherokee.
The taperwing and Hershey bar use exactly the same airfoil, the 65sub2-415. I like it because of its docile stall characteristics.
JimC offline
