porterjet wrote:There is a taildragger Grumman for sale on Barnstormers. Forget if it is a Tiger or Cougar.
It's a Yankee...kind of neat.... http://www.barnstormers.com/classified_ ... ankee.html
Brian - Steve's Aircraft wrote:Customer of mine HAD the Power Flow exhaust system on his Cherokee...According to him, it never did what they advertised anyway.
Tadpole wrote:porterjet wrote:There is a taildragger Grumman for sale on Barnstormers. Forget if it is a Tiger or Cougar.
hotrod150 wrote:Brian - Steve's Aircraft wrote:Customer of mine HAD the Power Flow exhaust system on his Cherokee...According to him, it never did what they advertised anyway.
That's the trouble with trying to get a straight report on some of these mods-- after a guy spends a couple grand on something, he's naturally pretty hesitant to admit that it doesn't work as advertised.
Eric
Bonanza Man wrote:hotrod150 wrote:Brian - Steve's Aircraft wrote:Customer of mine HAD the Power Flow exhaust system on his Cherokee...According to him, it never did what they advertised anyway.
Eric
Bingo. You'll notice you don't see any Mooney, 210, Bonanza, Colombia, etc, with droop wingtips. If you spend any time at all with these people you'll soon realize that if they could get 3 knots from a set of wingtips(or anything else) every one would have a set. And any speed mod has a greater effect on planes that go faster in the first place. I have a set of VG's now and I put them on the 182 I used to have. They do lower stall a little as well as reduce cruise speed by about 5 knots but I noticed nothing in handling on either plane. But it's not hard to find a 50 hour a year pilot rave about the changes in any of these things.
Eric
Brian - Steve's Aircraft wrote:We have never seen a cruise penalty with VG's either. VG's really help with slow speed aileron response flying heavy at altitude. And on the short wing PA-22/20 Pacers, that is where they need the help the most.
Brian.
Bonanza Man wrote:Brian - Steve's Aircraft wrote:We have never seen a cruise penalty with VG's either. VG's really help with slow speed aileron response flying heavy at altitude. And on the short wing PA-22/20 Pacers, that is where they need the help the most.
Brian.
If you don't see a cruise penalty then you installed them wrong. Simple as that. You put a measurable amount of drag on the airframe it's pretty easy to calculate the loss of speed. It's only going to be a knot or two on something slow, 100-120 knots TAS or so. A guy I met at Meadow Creek is from California and flies a Harmon Rocket, he and his wife are in Montana and Idaho every year. If you spend any time thee you'll come across them. He says he lost 17 knots, but he's starting at around 230 knots and has a more critical airfoil. There's no free lunch.
side slip wrote:Hmmmm, I think you've got it wrong bonanza man,
If you have lost speed with vg's, then on of two things is wrong with your installation; either you have the vg's too far forward on the wing, or they are installed in the correct spot, but are too tall. Both of these cases will cause a speed loss because the vg is sticking into ambient air.
Vg's installed in this manner will also collect ALOT of ice, yet when installed correctly, will not.
If you are flying a bonanza with vg's, IMO they should be about 1/4" tall, and roughly 8-10" back from the leading edge, of course the stc will give exact positioning.
Bonanza Man wrote:If you don't see a cruise penalty then you installed them wrong. Simple as that. There's no free lunch.
Brian - Steve's Aircraft wrote:Bonanza Man wrote:If you don't see a cruise penalty then you installed them wrong. Simple as that. There's no free lunch.
Let me see. What you are saying is that the last....O let me think....12 airplanes that I have personally installed VG's on have been done incorrectly..???? .......Brian.
hotrod150 wrote:Brian - Steve's Aircraft wrote:Bonanza Man wrote:If you don't see a cruise penalty then you installed them wrong. Simple as that. There's no free lunch.
You both put them on wrong-- they go on the bottom of the wing, for slower more controllable inverted flight. I thought everyone knew that!
