Dale Moul wrote:...... last step was to spray all the seams with corrosion-X, but if you do that it will seep and drip for at least a month as all the corrosion-X leaks out thru the seams and around rivets. the amount of stuff that rinsed out was amazing....
182 STOL driver wrote:......... WD40 will attack Aluminum so I don't use it. ....
hotrod180 wrote:182 STOL driver wrote:......... WD40 will attack Aluminum so I don't use it. ....
First time I've ever heard that.
Dale Moul wrote: ....WD-40 is corrosive because it is hydroscopic (I hope that's spelled right, it attracts moisture out of the air). when it is sprayed into a tight area such as a seam in a plane it will stay there and hold moisture into the seam.
Cannon wrote:I haven't found anything that cleans oil off the belly better than WD-40. The only problem is that the nozzle shoots a thin stream rather than a wide spray.
