Backcountry Pilot • concorde battery willnot fit into cessna 182 box
6 postsPage 1 of 1
Greetings
As the subject notes....I just purchased a 12V concorde battery RG. THe plane is a 1962 model F 182 with the plastic/bakelite? battery box at the rear of the plane.
The battery drops into the box and hookups are good, but the box cover will not fit because of teh top of the battery. I have heard that a little cutting of teh battery box cover will allow it to drop onto the battery.
Anyone with experience with this?
Thanks
Sean
seward offline
Re: concorde battery willnot fit into cessna 182 box
Don’t cut the lid. Warm it up where it interferes with the battery and press a wood block into it to reshape it. It’s even detailed in the STC instructions. If they didn’t include them, they’re right there on their website.
Check your paperwork. A weight and balance amendment may also be required.
Pinecone offline
Thanks for the reply. Turns out Concorde changed the website and material not available directly online. Fortunately the website does have a contact number and a suggestion to call before purchase (oops). Their tech specialist (Ashley) was very helpful and sent me a diagram for battery cover modification. I'll see how it works.
Sean
seward offline
I’ve done a bunch of them, quick warmup with the heat gun, press into place, done. Piece o cake.
AEROPOD offline
Finished tonite. Worked great.
Sean
seward offline
This website is amazing for this kind of information and the experience on this forum is second to none.
MW
185Midwest offline
Aircraft: C-185
6 postsPage 1 of 1
