Looking for constant speed operational technique for cruise and descent settings. The best way to operate your engine for life and fuel savings.
Climb, I assume levers forward but if there's discussion on that please do tell!
Kelly
River rat wrote:What you can do is run your plane full throttle at as close to sea lever as is reasonably possible while playing with the rpm. Whatever rpm gives you the best ground speed is theoretically the most efficient rpm for your prop.
Now you know that number, when you are climbing out dial your rpm back to whatever that number is and leave it there, then use whatever MP you want depending on how much gas you want to burn.
Jeredp wrote:River rat wrote:What you can do is run your plane full throttle at as close to sea lever as is reasonably possible while playing with the rpm. Whatever rpm gives you the best ground speed is theoretically the most efficient rpm for your prop.
I might be wrong but I don't this is very accurate. That's like saying take your truck out on the highway and what ever gear lets you go the fastest is the best gear to take off up hill in.
Gear, flaps, manifold, prop.Jeredp wrote:The POH will give you all this info.
Mister701 wrote:Gear, flaps, manifold, prop.Jeredp wrote:The POH will give you all this info.
Cary wrote:Every airframe/engine combination is likely to be slightly different. There are some rather usual "rules", however:*Take off and climb out will be with full throttle and the prop control all the way in, for highest rpm. Sometimes you'll hear that called "flattening" the prop.
*Some engines require reducing rpm to a climb setting rather than full rpm--check the POH.
*Most engines will handle a somewhat reduced rpm for cruise climb rather than full rpm.
*At lower altitudes, generally it's best to reduce MP (throttle) first, then rpm. At higher altitudes, that won't make any difference, because MP of normally aspirated engines is already pretty low.
*On descent, make up for slower climb by just nosing over and gaining airspeed--leave the prop alone and reduce MP as necessary.
Now with all that, I'll just describe what I do in my airplane (P172D, Lycoming O-360, CS prop):First, taking off from a low elevation airport and climbing to about 2000' AGL: prop all the way forward, throttle all the way forward. After reaching about 4-500' AGL, throttle back to 25", prop to 2550 rpm. Upon reaching altitude, throttle to 21", prop to 2400 rpm, lean. Results: 9.8 gph.
Second, taking off from a high elevation airport and climbing to about 2000' AGL: prop all the way forward, throttle all the way forward. After reaching about 4-500' AGL, leave throttle full forward (MP is already below 21"), prop to 2550 rpm. Upon reaching altitude, prop to 2400 rpm, lean. Results: 9.8 gph.
Descending: leave both throttle and rpm alone, pitch down. When the MP starts to climb above 21", reduce the throttle to 21", continue to reduce it to maintain 21".
For landing, reduce throttle just as you do with a fixed pitch prop, but once the throttle is below 12" or so, push the prop control all the way forward, in case you need to go around.
All of this stuff, your CFI should be covering, and it won't take you very long to get the hang of it.
River rat wrote:Not all aircraft have a POH for the engine and prop they are currently running.
Jeredp wrote:Mister701 wrote:Gear, flaps, manifold, prop.Jeredp wrote:The POH will give you all this info.
Yeah i skip the gear part cuz everything that I fly always has the gear down and locked, like it shoud be
whee wrote:River rat wrote:Not all aircraft have a POH for the engine and prop they are currently running.
Especially experimentals but that is part of the fun.
The Bearhawk I was flying had an O360 with a 78"Mac C214 prop. After much fooling around I found that it seemed to like 2400-2450rpm for cruise and I usually just left it WOT because I was operating at highish altitudes. Fuel burn was around 9gph.
Zzz wrote:These engines are detuned as it is. Why not takeoff at 2700? Is there evidence to show that can lobes are being stressed at 2700 rpm?
