Continental O-470 Nitriding process?
I have a Experimental class 108-3 with a o-470-K wide rod crank where the previous owner had it ground down to the 0,01". Unfortunately they did not Nitride it afterwards as per the overhaul manual. I would like to Nitride it here in Sweden, but I would need to know the exact process to use. There are a couple of Nitriding processes, (Gas or ION etc) and I want to use the correct one. Does anyone have any insight in this?
Br/Henrik
Cubswede offline
1
- Aircraft: Stinson 108-3, 2 ea PA18-150, 2 ea Jantar standard gliders
I'd call Aircraft Specialties Services in Tulsa Oklahoma and see if they will tell you what they do.
918 836 6872
Also looked at an Airboat forum and "
Aircraft cranks are Nitrided which adds strength and hardness. This is a three step process; rough grind, nitride and finish grind. Ion-nitriding will work on airboat cranks it is cheaper and two step process. Grind and have Ion Nitrided."
2326
