controller for the landing/spot
Just checking to see what is considered to be the best wig wag controller for the landing/spot lights, and or ones to avoid.. Thanks
kyle90 offline
2
Thu Apr 11, 2024 10:19 am
The ones with multiple settings on a rotary dial were installed in the CC-18s at work, but they all failed after 5-8 years if I remember correctly. Those controllers were replaced with a 3 position toggle switch and as far as I know those are all still working. Toggle goes off, flash, steady.
Troy Hamon offline
915
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 04iX0FXjV2
- Aircraft: Piper PA-22
Thu Apr 11, 2024 11:41 am
I’m also interested in a simple and affordable wig wag option. Troy what you mention sounds ideal. I think the max pulse units are fine but I only ever use 1 option so I’d prefer to just have a switch.
I’ve used this little thing before and it works to flash both my lights at the same time but no wig wag and I don’t love cycling the switch to go between steady and pulse.
https://www.crewdogelectronics.com/cata ... t-flasher/Would also prefer aviation grade but honestly if someone has a proven “experimental” unit I’m interested in that as well.
Thanks
Edit:
Just found this Whelen one that appears to function like Troy’s planes..
https://www.aircraftspruce.com/catalog/ ... 170000.php
asa on Thu Apr 11, 2024 1:57 pm, edited 1 time in total.
1533
Thu Apr 11, 2024 12:26 pm
Troy Hamon wrote:The ones with multiple settings on a rotary dial
I'm embarrassed to say the first time I saw that dial in one of the flight school's 172s, I thought it was an ignition curve selector because the aircraft also had an Electroair installation. The labeling on it is not exactly super clear what it means. It took me a few minutes to realize it was the flasher pattern selector.
3000
- Aircraft: None
Wouldn’t be certified
But I wonder if any of the police/EMS controllers/switches from whelen would work?
https://www.whelen.com/product/ulf44-un ... #gallery-4
LED or Super-LED® flasher with synchronization
60 Watts per outlet
Four outlet, four channel flasher with 62 Scan-Lock™ flash patterns allowing for alternating, simultaneous, and synchronized flashing lightheads
Each channel can drive up to 5 amps (60 watts) and is short circuit and thermally protected” Picked up a auction detectives car a while back, it’s got all the hidden flashers and stuff, the controllers and all seem tuff as nails, don’t see why it couldnt work on aviation lights, I mean a LED is a LED
- Retired
1678
