Backcountry Pilot • Corrosion work, need 3M DISCS, ACF50
7 postsPage 1 of 1
If we think we have corrosion issues on the Pacific Coast...check out the Atlantic:
http://www.bbc.co.uk/news/uk-22846645. :(
Re: Corrosion work, need 3M DISCS, ACF50
I think when they rebuild these sunken aircraft after 50 years at the bottom of the sea floor, they only reuse one part. :)
Zzz wrote:I think when they rebuild these sunken aircraft after 50 years at the bottom of the sea floor, they only reuse one part. :)
They must have one heck of a sheet metal and engine shop! Wow!
You can't keep a good data plate down!
Have the data plate and you have the airplane and/or engine! Love it! And don't forget to download the TCDS before the restoration :D
Never mind WD40 - "Experts plan to spray the wings and fuselage with water and a combination of citric acid and sodium hydroxide in an attempt to halt corrosion"
Anyone got some lemons?
Hope they are not too late!
I have been using citrus base degreasers that works great. Not cheap, but, cleans with zero corrosion. Plus, the cleaners are friendly to the environment ( I was assured )! Smell like oranges :)
7 postsPage 1 of 1
