An owner name Brian that posts on his blog added the following numbers to reflect his cost of owning a Cessna 182.
I love numbers and number crunching, so this interested me. He went to a good amount of effort to record his expenses for readers to learn from. I presume since it was published on a public blog, he will not mind it being repeated here. Others may find it valuable for comparison. It is dated 2008, so things will have gone up some.
Sunday, September 7, 2008
Cessna 182 Operating Expenses
There are more costs for operating an airplane than the fuel it burns and the original purchase price. When I was thinking of owning, I saw some breakouts that helped. I thought I would share how my expense have been going for the 4 years I have owned the plane. If you are considering renting vs owning you might also want to look at my past blog entries on renting and owning.
Repair Costs at Annual and Other Times
Many repair costs appear at annual inspection and at other times. See my other post about my latest annual inspection. I fly about 120 hours a year and this probably influences how much repair typically happens. My plane is a 1974 C182P. Age might make some difference, but I have heard of new planes with similar expenses.
Here is a list of different repairs and improvements I have done:
1/11/05 prop control: $204
Known needed to be fixed at purchase of plane.
1/17/05 labor prop control, cylinder head probe: $406
5/13/05 Filter adapter: $437
6/7/05 annual + nose strut+ cowl flap hinges + carb heat+filter adapter install: $2701
8/15/05 cylinder fix: $1158
11/18/05: vor indicator fix: $65
2/13/06: EI UBG-16 engine analyzer: $1465
3/29/06: new muffler, exhaust: $3363
3/29/06: EI install $900
7/5/06: annual + tires +brakes+aileron rod+ mixture cable: $2445
vernier mixture cable improvement portion was: $271
12/14/06: pitot-static, vor indicator fix: $422
5/11/07: attitude indicator $1097
6/19/07: GNS430 Waas upgrade $2001
8/14/07: annual + cylinder + engine mounts + baffling + fairing fix = $4224
cylinder portion was about $928
11/16/07: short in instrument lighting (found in EI install): $401
9/5/08: annual + cylinder + carb box + spin bulkhead + mags = $3800
cylinder portion was about $900
In order to come up with a yearly budget, I will consider that some of these items are from the first years of owning (such as the exhaust fixing and prop control). I will also not include the cylinder fixing in the normal plan, but it should be considered as possible. The annual inspection is around $1200/ year as well.
This totals to about $3272/year including the inspection. For simplicity, we will say $1200 is for the inspection and $2000/year is for general maintenance.
Also keep in mind a budget for upgrades. I ended up spending $5038 total for 4 years upgrades plus fixing a short in the EI install. These were relatively small upgrades. Interior, Paint, and many avionics upgrades are much much more.
Keeping costs in control is very important. If you are not careful, I could see maintenance costs doubling. I recommend taking Mike Busch's Savvy Aviator Seminar and joining the Cessna Pilots Association or a club for your type of plane and ask lots of questions. The more you are involved with understanding the maintenance, the better.
Overhaul Costs
Planning for a potential engine overhaul is something you should do and it is a major expense. As Mike Busch indicates in his Savvy Aviator Seminar, I would recommend using TBO as a guideline, but not a requirement.
But how much does an engine overhaul cost? I am still trying to figure this out. One spot to look is Aviation Consumer. They have an article onverhauling shops. There are a number of things that I think are left out from the costs listed there such as overhauling the prop and governor and the removal and reinstallation of the engine. But it is a starting place.
So for purposes of this analysis, I will use engine overhaul of $24,000 engine + $2400 R&R. Prop overhaul of $2500 prop + $2000 governor. Both of these to be budgeted for 1500 hours.
Yearly Fixed Costs
•Annual Inspection: $1200
•Repairs during annual and other times: $2000 (sometimes a cylinder fix for $900)
•Hangar: $290 * 12 months (some hangars are much more expensive)
•Insurance: $1277
•Loan or the cost of money in the plane?
•Improvements in Avionics, Interior, and Paint?
•Total = $7777
•If you fly 120 hours a year and do not add for a loan, $64.80 / hour
Hourly Costs
•~13 Gph at maybe $5.50 = $71.50/hour
•Oil change every 40 hours = $75 oil+filter + $22 oil analysis + do labor myself = $2.43/hour
•Engine overhaul budget every 1500 hours: $24,000 engine + $2400 R&R = $17.60/hour
•Prop overhaul budget every 1500 hours: $2500 prop + $2000 governor = $3/hour
•Total = $94.53 / hour
Combined Fixed + Hourly Costs
•For 120 hours / year is: $159.33 / hour.
•For 50 hours / year is: $250.07 / hour
Compared to Renting
At our field, there is a Cessna 182 for rent for $155 / hour. It is not as nice as ours and is not hangared which can be nice on cold days. Having the plane available when you want is worth something that is hard to count. The $159.33 / hour cost also does not account for a loan or the money you have paid for the plane. If you are not flying 120 hours per year, the rental looks better and better.
Summary
Hopefully this helps for anybody thinking about owning. If you have a different experience, please feel free to share.
/Brian
