RangeFlyer wrote:I fly a C175b with O-360. My CHT's never climb over 360 in a climb, and 320 in cruise, even on hot summer days. Baffle material is good with no gaps anywhere. Now, my Lower cowl has louvers, installed by the original dealer in Kansas to help cool the then GO-300. Can't tell you how much this helps, but my engine does run cool. Now, to figure out how to get it warmer in winter.
Dave
EZFlap wrote:Please forgive any unintentional "pointedness" or harshness of this comment...
Why do you think this aircraft below has this type of cooling system?
You have an airplane with a lot of power, that climbs at very slow speeds, and operating in the middle of back country nowhere they really don't want you to burn up the engine. The Super Cub basic aircraft platform has existed for 60+ years, and the only possible reason for someone to go through the effort to re-design it is because the new design would cool the engine better than the old standby time-honored system. Putting the cowl flaps on the side of the cowl was not a mistake, or a wild guess, or a gamble. The Cub Crafters team are pretty f***ing good at what they do.
I'm pretty sure that they did a computer CFD ("clown puke") pressure survey first, to verify that the pressure on the side of the cowl was indeed lower than the pressure at the bottom of the cowl, at slow speed and high AoA. When they verified that, I'm pretty sure they tested the two cooling systems (bottom exit and side exit), and verified that the side exits were worth the extra effort, because more air flowed through the cowling. When you have an over-powered airplane, and extremely slow speed capability, you need to use the cooling system that works better.
So if there are problems cooling a back country 172, and all the usual suspects (baffle seals, inter-cylinder baffles, etc.) are not the problem, and adding a "seaplane lip" at the bottom of the stock cowling doesn't solve the problem... then the problems that were built in to the factory cooling system may have to be looked at. Retarding the ignition timing is a price that you shouldn't have to pay. You could just as soon take off with the throttle 3/4 of the way forward, and at least have the full engine power available in cruise-climb, or on cold days.
If you put duct tape over the opening where the air comes in or out of the cowling, how much would you have to retard the timing then?
Sorry to be the guy with the bad news, I believe that you might be looking in the wrong area to solve the problem.
