Backcountry Pilot • Cross country flying in the Nevada Triangle
5 posts • Page 1 of 1
I plan on possibly flying my ole 182 VFR from Reno/Stead, NV (RTS) to French Valley Airport (F70) near Murrieta, CA. It will be roughly a 4 hr flight following Hwy 395 southbound with 1 stop at Lone Pine (026) or Inyokern (IYK). I haven't flown this route before and understand strong winds can create dangerous mountain waves along this route. I would leave at first light to get through this section with the minimum amount of wind & temperature. The trip would be Wed 13 May or Thu 14 May. Looking at the forecast-ed winds leaves me with questions. If there was a cross wind rolling off the Sierra Nevada's from the W at 25+kts, will that create a mountain wave? Are you affected by it if you were at 5k?
So at what point is the wind & temperature dangerous?
SkylaneSam offline
Re: Cross country flying in the Nevada Triangle
Whether 25 knots is too much wind depends on the altitude of those winds. 25 knots at 10,000' probably means some rotor action in the lee of the mountains below ridgetop level along 395. There might not be much turbulence. It's hard to say. The forecast winds aloft were pretty light the morning that Steve Fossett crashed near the Minarets, and wind probably had something to do with that crash. I've flown low in the Owens Valley a few times, but usually go high (like 14k+) when I'm passing through.
The smoothest route with the most outs would be crossing from Stead to the west at Donner Pass following I80 to Blue Canyon, then down the central valley to the LA basin and French Valley. That's how I'd go if my wife was with me. If I'm flying by myself, I'd see what the winds are doing on the peaks own the Sierra crest and at the airports along the Owens Valley right before taking off and decide then on the route and altitude. The 395 route is really pretty, and lower is prettier.
Good luck and enjoy, however you go.
Terry
CAVU offline
Well you might be airborne by now but wind at my place 7k feet not too far from stead is Nuking this morning . Thursday (tomorrow) looks better. 25 kts at the ridges going down the east side isn’t really that much wind. Probable won’t be cruising at ridge top level in the 182 on that route anyways being that these ridges are 13-14k ….. as mentioned the route over Donner summit into the sac valley can provide a much calmer flight if its ripping on the east side .
low rider offline
vail
I’d be more worried about flying into that nightmare they call the LA basin.
low rider offline
vail
A little late on this, but I've flown that same-ish route several times, they say anything above 20 knots at the peaks can create wave/rotors. That's some high country down there, I recommend staying above the peaks when downing. Watch out for that restricted airspace.
CParker offline
Aircraft: 1979 TU206G
