Cooperd0g wrote:Zane wrote:I think a lot of certifications are achieved by simply placarding an operational restriction, in this case the CC340. I've read that the turbocharged Rotax 914 has a similar full power duration restriction, but theoretically you can run it WFO for as long as you want. It just might get really hot.
That CC340 looks really cool though. I'd never read in depth enough prior to now, but it sounds like it loses some weigh by dumping the mags for electronic ignition modules, and some lightweight exhaust. It has a cooling plenum, which I guess enhances air flow over the cylinders better than less aerodynamic baffling.
I'm sure Tadpole will be able to better answer your questions in a day or 6.
That is kind of what I figured. I like the idea of a Husky or Cub Crafters Top Cub, but they Carbon Cub EX looks to have even better performance because of the reduced weight. Then again, do I want to build it and would I add stuff like heat and other things that would increase the base weight and make it perform similarly to a Husky or Top Cub.
I fly a carbon cub. I have flown it a lot with Ladd who until a few weeks ago had a top cub. He sold it and now has a carbon cub ( actually the proto type carbon cub with an IO-360 it won the valdize stol comp a few years ago) He will be happy to tell you that the carbon cub out preforms a top cub by a mile. Thats why he sold it. He got sick of needing twice the take off distance and crusing 15 mph slower while burning more fuel. Not to mention climbing 60% as fast.
The 340 will run as long as you want at high power the rule is just to comply with the lsa limits.
On a side note don't be to quick to opt for a 360. Ladd's new plane has a IO-360 rated at 220 hp but its weighs more to. I took off behind him we both did a full power climb at 70 mph i was able to climb above him while slowly passing. I was suprised and so was he ( although not pleasantly) The moral of the story, light weight is more important than either of us thought. Ohh and a husky is a great plane with a lot of good all around uses but we have flown with them a lot and they can't hang with a top cub let alone a carbon cub when it comes to STOL. ( they do leave both of them behind in cruise though)
I have 275 hours on the 340 and so far so good but i really don't know if ECI part are any good. (i really hope they are time will tell)
