Is it Mr Coyote Hoover?? quite nice! Do you need a different rating for motor gliders??
I wondered if you were going to restart. I stopped my prop on a champ once and the re-start was going almost straight down and that required a kick of the rudder.
The T-craft does this kind of stuff better than any other airplane ! Great video.
Ross Briegleb, one of my glider instructors, used to fly one T-craft with the prop not mounted on the crank... and the tow rope wrapped around the prop flange of the crank... towed to altitude by another T-craft that had 100 HP. He would release the rope knot from the cockpit of the un-powered T-craft and do an airshow aerobatic routine with it.
Another famous sailplane competition and flight test pilot named Dick Johnson had an altimeter vibrator made from an engraving pen that he used for glide tests on high performance gliders.
Pops, look into Velcro'ing a plain old mechanical glider variometer on top of the dash when you're playing glider. A vario is an ultra sensitive rate of climb indicator. There's all sorts of exotic air probes we used to have hooked up to them to cancel out climbs and dives, but for these basic purposes you can essentially just leave it open to cockpit vent or any open static port. You'll be amazed at how much you can fly with that prop stopped if you have good air movement information. In Austin, you can probably glide back and forth along the upwind side of those ridges for hours at a time in a good westerly breeze.
