hey guys, i have been reading that del aire is the only one who offers an stc for a 170 180hp conversion, do they have a web site or anything? i couldn't find one.
thanks
Tom
shortfielder wrote:HarryDelacur ACT Del Aire 559.784.9440 These are done from oldnotes, so the # may not be any good, but worth a shot. If I remember right,he does baggge doors also.
Good luck. That's a good conversion for the plane, might be cheapr to buy a nice one all done, if that matters.
Gary
shortfielder wrote:Richard
I had thought that IO-360's were 200 hp. If they have some that are 180hp, does that mean lower compression/auto gas?
Gary
ccurrie wrote: none of the 180hp licomings are stced for mogas as far as I know.
EZFlap wrote:The phone rang, Harry disappeared in the middle of our co nversation, and his shop assistant told me to go home because Harry could be on the phone the whole night!
wannabe wrote:Harry also has two STC that sort of go along with the bigger engine and that is two STCs for larger tanks. The Extended Range tanks go out one more rib on each side for 7-1/2 gals. per side. Equivalent to 175 wings. His LONG range tanks, which is what I have, adds 15 gals. per side for a total of 67 gals. This is done by simply Welding an additional tank onto the outboard end of you existing tanks. That keeps all of the "systems" the same. No additional plumbing, no wiring, no gas inside. Simple.
Users browsing this forum: No registered users and 35 guests
