Note: using MyE6B app also on iPAD
I soloed at Scottsdale Municipal Airport, AZ back in High School. There was a boarding school called Judson in Paradise Valley back then. I convinced the headmaster to allow me to take a cab to the airport in the afternoon after classes. We also flew radio controlled at the school. A new Cessna C172 was $14,000.00, VFR.contactflying wrote:I got my CFI while at NAU. The FBO used the new AA1-As that were later Grumman. That's where I got this "airplanes won't necessarily climb" tick, which has worked well for me ever since. So a flatlander gets off but can't climb. Level in low ground effect and down drainage egress helps a lot. As does default leaning.
Check ride with FAA back then was at Scottsdale. Students could fly sanctioned pattern down there.
The Piper Cherokee 140 is dangerously under powered. A CFI was killed and the student injured on the Island of Lanai during a night training flight. DA never is above 3K and generally strong headwinds. But...dogpilot wrote:...The guys that really get affected here are in Bonanzas and Piper Cherokee 140's. Bonanzas can use all the runway here and climb at a very leisurely pace if they are heavy. The Pipers get stuck here,...
Turbine helicopters have considerable power vs. weight in contrast to my reciprocating engine.tcj wrote:Hannagan Meadows heliport near Alpine Arizona is on the Mogollon Rim at 9100 feet. I've hitched a ride on a Bell 407 out of there on a hot day. It seemed to have quite adequate power. The kids on the helitack crew called that place a "Suck hole".
contactflying wrote:And like the fixed wing, the big round wing will accelerate in low ground effect where climbing would cause settling with power.
contactflying wrote:Are you familiar with the Army's simple TOL Card for estimating power needed at a higher DA from takeoff? We had good luck with them at Mountain Flying Course at Ft. Carson. It is based on power to hover 3' at takeoff elevation. Up on Pikes Peak at 14,000 we zero airspeed about a 3/8 mile out and set the calibrated torque
with collective. From there to hover in the LZ, the collective is not moved. To go down on the glide angle we manipulate the cyclic to get a little settling with power. To go up on the glide angle we move the collective forward a bit. It is amazing to not have to touch the collective while settling into a 3' hover.
Side note: The FAA Helicopter Flying Handbook, 2019 finally delineated and properly defined “Settling with power” and “Vortex ring state”. Also, The Vuichard Recovery technique is the most used now for “Vortex ring state”.contactflying wrote:1976. I was in the 717th Medical Detachment to the NMARNG. The training unit was regular Army, 4th Infantry Division. We were losing too many helicopters making the fast approach used to limit exposure in Vietnam. When all that collective needed to decelerate caused rotor decay, the pilot would run out of left pedal and the helicopter would spin right in the high LZ.
A good slow approach works in normal circumstances. When the Army needs troops delivered up high or medevaced out, this technique works well. It allows the helicopter to perform the mission at a higher DA than would be possible with even the normal apparent brisk walk rate of closure approach.
Yes, vortex ring or settling with power is a concern. It can be flown out of by increasing airspeed. Increasing just enough to quit settling causes less descent rate.
Tom Horan, city attorney for Albuquerque at the time, was commanding the 717th. He would know the particulars, but I assume the technique was approved because the 4th Infantry ran the school for regular Army as well.
I googled the mountain flying course and found both Army Aviation High Altitude Mountain Environmental Training Strategy, RA, and Colorado Army National Guard High Altitude ARNG Aviation Training Site. I was never fully aware of my situation and am now somewhat senile as well, but I am certain the instructors were regular Army when we took the course in our two week summer camp.
