This could be interesting.
http://www.aopa.org/News-and-Video/All-News/2014/July/30/American-Champion-Aircraft-to-produce-a-diesel-bush-airplane?WT.mc_id=140801epilot&WT.mc_sect=osh
SkyTruck wrote:Am I the only one that caught the part about adding Fifty Thousand Dollars to the price of the plane?
Timberwolf wrote:SkyTruck wrote:Am I the only one that caught the part about adding Fifty Thousand Dollars to the price of the plane?
Nope. Until they get a bit more realistic on the price, I don't see very many people running out to get one. I'm surprised to see companies with these engines not putting them out there for the experimental crowd for reasonable prices.
joejenie wrote:I can climb faster and go a lot faster. A husky can probably land a little shorter though. I'm thinking they can land in 150-200 ft and I can land in 250 ft. Takes me an extra 100 ft to get off the ground as well. Of course, I'm never landing on anything shorter than 500-700 ft anyway, so no problem. Those speeds are at 12-13 gph. At 9.5-10 gph, I can do 130-131 mph. Legal gross weight is 2150 lbs. Mine weighs 1438 lbs. IIRC. I know the useful load is over 700 lbs. Mine is a little heavy because it has bushwheels and it has an IFR panel (I would have done it different if I spec'd it out). My previous Scout had the same gross and weighed under 1400 lbs. This one still out performs my old one though due to the bigger fuel injected engine.
I took off 1-2 minutes behind a friend at upper loon in ID and within 8-10 minutes, I was 1500 ft higher than he was and passing him. Both of us where going full bore and had 2 people and half fuel in our airplanes.
