Hi Goose,
I struggle with this one a lot (with the exception of AK). Most hunting occurs during my busy work season, thus the 'fly in' thought process has huge appeal.
Having hunted big game in all the states on your list, I think you're going to find the flying prior to hunting very restrictive in most of them, except AK. At least in the sense of flying directly to the field, and then also with respect to the post flight harvest interval.
Nevertheless, some time can be burned up setting camp, and glassing / scouting. In the event that flying directly to the field proves not worth it, some hunts still benefit from flying to the nearest strip.
I would also add that (and I'm sure you know this) your list is missing the two best Muley / Elk states.... I suspect this is because the majority of the hunts there are draws , and the states are considered 'premier'. Having said that, even the premier states have 'sleeper' hunts, that aren't too tough to draw. Start putting in now, and in the next year or two you won't be looking for another OTC tag.
Here are two juvie bulls that my daughter and I killed the year before last on the last day of a hunt like that. We spent 7 days chasing a 380+ 7x7, and took these with hours to spare. I know, I know... tomorrow's trophy's today...
but they ate well anyways.... It was my 5th hunt in 10 years in that unit, and the success has been exceptional. To put it in to perspective, we drew it again this year in addition to a pair of sleeper muley tags that will undoubtedly get filled.
I back that hunt up with an OTC elk in SW CO, and an easy draw combo in SW MT. Between the three the season doesn't go dry unless work is on fire.
The unit my strip is on is over ran with desert mulies to the point that there has been depradation hunts 3 years running now, and I know of more than one 200 class buck in the area, but alas, that draw is done for this year. If you are an archer and want to try that, it is OTC, shoot me a PM The only draw back to the archery hunt here is that it is the last hunt of the season, and they get a TON of pressure.
Take care, Rob
