Backcountry Pilot • Door latch mousetrap spring
12 postsPage 1 of 1
I found lots of old threads all over the internet about the latched and springs, but it appears that they guy that used to make them is no longer with us.
I have a '53, it appears that the mousetrap spring is broken. Does anyone have a current source for them? I"d prefer not to go the route of making my own.
StillLearning offline
Re: Door latch mousetrap spring
Pretty sure Bruce on the 170 forum still makes them for 170s. Not sure if they are the same?
I found mine on Amazon! Not sure what your part number is, but it’s worth checking it out.
(for my ‘68 182)
Cessna Baggage Door Latch Repair Kit Spring S1359-7, S1359-8 & 9 https://a.co/d/cxpOvdP
AK737Pilot offline
Aircraft: Cessna 182L
FOR SALE: At your request, I can make fresh "mouse-
trap" springs, part #0411554/0511247-1, for your door
latches. This is a copy of the original door catch spring.
Fits all years and models of Cessna 170 and early 172.
Two springs for $15+ mailing. Also, available door handle
return springs found on 170 serial 27373 and on, but
retrofittable to all 170 and early 172 model door latches
part #0511119. Two springs for $25+ mailing. Email
[email protected]
daedaluscan wrote:FOR SALE: At your request, I can make fresh "mouse-
[email protected]
I haven't gotten a chance to install them yet, but I had Bruce make me some owner produced parts for my early 172, they shipped quickly and look great!
PilotPeat offline
Years ago, someone in the 120/140 Assn provided instructions on making a jig for bending up your own mosuetrap springs from music wire.
I made a jig, made a few springs (which worked only so-so), but gave away the jig when I sold my 170.
I asked the guy I gave it to, to see if he could find it.
He found it & will be giving it back to me, I'll post a pic when he does.
The Amazon one was way weaker than the original, and was hard to make work, but it worked.
Ross4289 offline
Aircraft: 185
hotrod180 wrote: Years ago, someone in the 120/140 Assn provided instructions on making a jig for bending up your own mousetrap springs from music wire.... .
Here's the pic.
The wood is .645" thick.
I used .032 music wire.
An 1/8" drill bit goes in the hole,
You put the wire in the saw-slot, wrap it around both sides of the wood,
take two turns around the drill bit, and cut the tails off at 1-1/16".
The springs I made for my 170 weren't all that satisfactory,
but they were better than the broken springs they replaced.
Here ya go....
dsbur offline
Thank you! Filed away for future use.
I love collecting useful information like this and occasionally actually use it or have it to share with someone in need.
PilotPeat offline
dsbur wrote: Here ya go....
Yes, that's what I used when I made my jig.
Thanks for posting.
I emailed Bruce, but got no response.
12 postsPage 1 of 1
