L18C-95 wrote:A bit recondite but hopefully on BCP there are pilots with experience of both types.
I sometimes feel that the lift augmentation devices and the resulting EW came from the same philosophy that put boundary layer control on the Blackburn Buccaneer - the weight of the cutting edge technology may have defeated the original purpose.
In any event would these two types, in practical every day terms, outperform a simple similar vintage C-185?
I have time in the Helio H-250 Courier and the 185. The O-540 in the H-250 isn't up to the task of dragging the beast up out of a really shortfield loaded up, but does pretty well half loaded. The geared engines swinging the giant prop are an entirely different story. Those pull really hard out of the hole. I think that these engines are very expensive, if not impossible to overhaul, while the IO-520s are pretty ubiquitous. I consistently land my 1967 180 in 450 feet and takeoff about the same with a load at my home field and standard temp. The 185 takes off a little shorter. I can easily land the Helio in 200 and takeoff in 300, so the short field performance is much better. The 180/185 are MUCH more fun to fly IMHO, but if utility is your main objective a Helio H-295 is really hard to beat. The main gear on the Helio is awesome. The tailwheel on the Helio is carrying a really high load because of how far forward the mains are. I wouldn't want to drag it around through soft or rough stuff. The mains and the tailwheel on the 180/185 are awesome! People who say that the 185s are truckish have never flown a Courier. The Ailerons are extremely heavy, and I believe that there are springs in the system for centering, which make them feel really sluggish, though roll rate is decent. The Helio is a puprose built aircraft, and the 185 is a very versatile plane.
Here is about my fourth landing in the H-250, at about 250 feet. I have since shaved 75 feet off of that.
