Backcountry Pilot • Double puck brakes....
This subforum is meant to organize Cessna 182-related topics.
14 posts • Page 1 of 1
I have the opportunity to pick up a set of double puck wheels and brakes ...1956 Cessna 182...8:00 mains....mix of hard and soft field runways...not a hard core back woods aviator...1800 foot grass lengths...are the pros sufficient to offset any negatives..weight is minor and my annual is coming up so not a major downtime or cost to install...one comment in the threads suggest excessive brake application can lead to locking the tire and severing the valve stem...a rather unpleasant prospect...! What I want to avoid is the natural desire to “upgrade” and bring with it more risk than reward.....btw the brakes I have are working fine....
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Re: Double puck brakes....
Airdave100 wrote:....What I want to avoid is the natural desire to “upgrade” and bring with it more risk than reward.....btw the brakes I have are working fine....
"If it ain't broke, don't fix it" comes to mind.
That said, if you ever want to put on bigger tires,
the STC for those might include a requirement for "heavy duty brakes" or similar.
Agree with hotrod; if it ain't broke........ Our 56 182 had single puck with GY 8.50s and did pretty well; but, we added 22" Desser (4 ply) smoothies for backcountry fun so added ABW dbl puck and really like them. Home base is paved so 40-50% TO/landings are on paved RW with no issues-yet...2+ yrs. We run 15 PSI in Dessers.
flyingjack offline
Aircraft: Husky/T206H
Applying brake (in this example a resistance on a rotating object) induces a torque vector in the direction of the rotation. Employed in a conventional (tailwheel) configuration, the weight on the tailwheel is reduced when the braking resistance is applied as the mass in motion attempts to rotate about the axis in which the resistance is applied (assuming the resistance is equal to both main wheels thus no yaw induced). The same forces are in play on a tricycle (nose wheel) configuration, however, once the nose wheel contacts the ground as it picks up its designed portion of the weight of the aircraft shed by the reducing lift vector of the wing, the weight on the nose gear is increased. With increased rotational resistance (braking) the weight on the nose wheel and associated support, (struts, firewall attach, and airframe) are increased as there is a rotational force and a moment arm (distance from resistance application to the nose gear attachment). An analogy is placing a pipe on a wrench to apply more rotational force. Something will eventually move given enough applied force, unfortunately it may not be the part you were trying to remove. It may distort the part, the wrench itself or the pipe as you may exceed its design parameters. Most components are engineered and thus manufactured to meet a specific purpose. Changing one seemingly minor component usually effects interacting components. Just a thought. Risk/Reward is the proper question indeed.
TR offline
Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
Why not?
The planes I flew with very powerful brakes, a Stinson with upgraded disks and a few PC12s, just get use to them on a longer runway first, before you take them in anywhere short enough you NEED brakes, after you and the brakes are seeing eye to eye, it’s no factor
It’s like a proper high HP vehicle, you can still drive it like driving miss daisy, but it’s nice to know you got that power if you need or want it, same with brakes
Double Pucks are Awesome. You don't have to use them but when you do need some braking power you'll have it available and it could save you in the event of a long landing, or when you want to go into a really short strip. I love my double pucks. $pendy but worth it if you have the dollars.
Josh
Dog is my Copilot offline
Aircraft: 1958 Cessna 180A
Thanks to all for the advice….I also feel I got a short lesson in mech engineering and torque vectors….which I know understand. Seems to makes sense to add…as said…why not…if you accept and respect the fact that you have added “power” to a system greater than the original design…one of our members uses Zoom Reserve as a means of explaining accessible energy…so too are DP brakes perhaps in the reverse….just cause you have them doesn’t mean you need to stomp them on all landings…but if things get ugly sure would be nice to have….appreciate the Community…
Airdave100 offline
The next question to ask yourself is do I still have aluminum axles.Further down the rabbit hole you will find two doors.One is marked steel, the other Titanium.. #-o
VT180 offline
Ok….I know I have solid aluminum not hollow……..not steel or titanium…so do I need this upgrade as well……?
Airdave100 offline
I would have a conversation with your IA. He will most likely say that he recommends steel but not required unless you are going with larger tires.Titanium's most noticeable effect would be on your wallet, although I must admit I keep looking at it.
VT180 offline
Airdave100 wrote:Ok….I know I have solid aluminum not hollow……..not steel or titanium…so do I need this upgrade as well……?
I understand the troubles with aluminum axles has been the hollow ones.
While I'd rather have hollow steel axles, my 180 has sold aluminum ones & I'm good with that.
Double puck brakes will not really contribute to more lockups. They will change your brake feel substantially, and take a bit of getting used to. You will have more available braking for the same amount of pedal pressure, but you will also have more pedal travel because you are moving more volume of fluid before the pressure ramps up.
If anything, you'll probably notice you need to deflect MORE pedal to get the same braking, and right on the edge of lockup you should have a more fine control over the amount of braking applied. Also with more pad area on the same rotor, you are likely to get more effective braking available before lockup because you will be able to apply more friction with less pressure. As the pressure ramps up, the lockup is more abrupt.
Basically, other than weight, and the fact that you can get your rotors hotter, all good things.
WorkingWarbirds offline
Aircraft: Champion 7GCBC
Mooney M20E
Globe Swift
Thanks again for all the comments and counsel….I’m going to install them next week when we take Old Blue down for the annual….like any change or upgrade a period of exploration seems right….
Airdave100 offline
Installed the double pucks yesterday…wow…did the steel axels as well…they feel great …subtle power in the pedals…first few grass landings noticeably shorter…total of 4 pounds additional weight…thanks for the advice….
Airdave100 offline
