I agree.flyer wrote:Both mags having impulse couplings should be an advantage for starting. Both plugs in the cylinders will fire. imop
If only one is impulsed, the non impulsed can fire before TDC as its advanced. This can cause kickback. That's the main reason.contactflying wrote:Flyer or David,
Pawnees had two mag switches and button start. Why did the mechanic not want us to start with both on when only left had impulse? Can't remember how many times I took off on left mag. Most of the planes had impulse on both mags so just flipped both switches to start.
Jim
corefile wrote:.... I’m replacing my old L-R-Both-Start keyed switch with a push button and two mag toggle switches. .....
contactflying wrote:Well said, hotrod180. I occasionally got into a Pawnee with hot mags. Often I had been the pilot who left them on. Only left the key on both once in 10,000 hours in Cessnas.
