gbflyer wrote:Only use MMO in experimental Lycomings and Continentals. Putting it in a certified engine will result in an immediate lightning strike to the user.
RockHopper wrote:gbflyer wrote:Only use MMO in experimental Lycomings and Continentals. Putting it in a certified engine will result in an immediate lightning strike to the user.
And all your hair will fall out too. But, amazing how that red solvent will clean valves that won't stick in the guides and your rings will be nice and free if you run it in the fuel. Just pure snake oil that you will find used by many AG round engine guys. Wonder why farmers with old machinery that keeps on running year after year have that wintergreen smell when you walk by them? Dem old farmers don't know nuthin eh?
8GCBC wrote:CamTom12 wrote:I use MMO in my fuel and get regular oil samples analyzed. Since starting the MMO I’ve noticed smoother engine operation and my oil samples are coming back good. I️ consider it preventative maintenance against 100LL. I’m also experimental.
Run MoGas! If you can get it down there. I tried MoGas in Alaska (GBflyer turned me on to it) loved it! No lead is good, even Lycoming approves it on my serial number! But, it's hard to get in Oregon cosidering how little fuel I use. Opinion.
Hammer wrote:
As for dead pax and a FAA forensic engine investigation...ya, could happen. But if I believed I was going to kill a pax in a airplane crash I'd quit flying right this minute. Operating with that potential eventuality in mind doesn't make a bit of sense to me.
Hammer wrote:
From that perspective, a multi-weight oil that flows more freely when cold is going to be a better engine protectant than any straight-weight oil, even if the straight weight oil does a better job once at operating temperature…something a lot of people claim, but which is, again, purely anecdotal.
Of course there are a thousand and one variables, many having to do with how and where said engine is operated. Most of our engines self destruct while sitting, not running…totally different that a “working” engine that rarely sits idle.
And before the flamethrowers get sparked up, I don’t have a valid opinion on straight vs multi oil, whether MMO should be used, or if CamGuard is worth the money. I run what I think is best in my engine and recon everyone else is welcome to do the same.
ShadowAviator wrote:DON'T just idle it for 15 min, and REALLY DON'T just turn the prop over. Get that oil hot and sticky, then sling it all over the engine.
Users browsing this forum: No registered users and 26 guests
