Backcountry Pilot • Dynon D180 AOA
Dynon D180 AOA
2 postsPage 1 of 1
Dynon D180 AOA
Hello All:
I recently purchased a Rans S7 :D . It has a Dynon D180, but does not have the AOA probe. I am considering adding the AOA probe or some other AOA system. I saw a couple nice ones at Oshkosh, but they would be more expensive than adding the Dynon probe.
Anyone have experience with the Dynon AOA or recommendations of some other AOA system?
Thanks for your advice
BTV
BTV offline
FindMeSpot URL: https://share.delorme.com/BrandtVermillion
Re: Dynon D180 AOA
I have a Dynon D100 in my RV, and built my own probe for cheap. All you really need to do is have a second pitot tube that has its end cut about 45 degrees compared to the "normal" pitot, which is at 90 degrees (i.e., directly into the flow of air). Here's a link to the photo of mine:
http://www.vansairforce.com/community/s ... hlight=AOA
on the VansAirforce site.
Cost is almost nothing, just a bit of tubing. You do have to calibrate the system in flight.
Greg
GregA offline
Aircraft: RV9
2 postsPage 1 of 1
