It shows at a 20”/2200rpm cruise at 7500’ an ultimate range of about 775 miles on 55 gallons usable.
The answer is no. I checked my C180A manual which gives the same information, but that information is not accurate. They didn't include a fuel reserve or the fuel needed to climb to altitude in their calculations. I can fly at a reduced power setting 17-18" 2200 RPM at 8-10 K burning around 10 gph. Cruise is around 125 KTAS with a O520 engine.
Realistically it would look like:
Time to climb to 8K - 100 knot climb for 12 minutes - 0.2 hours - 4-4.5 gallons = 20 nm
Cruise 125 KTAS X 4 hours at 10 GPH = 500 nm
Decent 130 KTAS at 0.3 hours at 10 GPH = 39 nm
4.5 hours of flight, 559 nm (642 sm), 47.5 gallons used.
I really hate legs longer than 3-3.5 hours due to the size of my bladder and the need to stretch the legs. I usually try to land with at least 10 gallons in the tank. You might be able to stretch the fuel a little further in that you have 29 usable gallons per side in level flight and I have filled 29 gallons in the left tank previously. It hasn't been too much of a problem for me since most of my legs are less than 500 nm.
Josh
