Backcountry Pilot • Early 180 vs Early 185
48 posts • Page 2 of 3 • 1, 2, 3
Re: Early 180 vs Early 185
mtv wrote:Handling qualities of various airplanes are individual and often very different to different pilots, based on their individual experience.
Fly a Pitts Special when you’re used to driving around in a loaded 206, for perspective. Or any of the RVs. Almost “twitchy”, but fun? You bet.
Would I want to fly a Pitts on a long cross country in summer heat? Oh, yeah, but you’d be flying it every inch of that trip.
So, all the descriptors each of us uses really need to be viewed as framed by our individual experience.
I once told a check airman that I really liked the control harmony of the Beaver. He told me I was full of it......but he was a wanna be “big airplane” guy. Who never got there. Me, the Beaver was just about perfect, but I didn’t (and still don’t) know any better.
If an airplane’s handling pleases you, buy one of those.
I wholeheartedly concur about the control harmony of the beaver. Only aircraft I have flown that has equal or better harmony was a Stearman.
Troy Hamon offline
Aircraft: Piper PA-22
I'm going to state the obvious first; that which should not have to be mentioned on the internet. But here goes. What comes next is only my opinion.
There becomes a normality to every plane you fly. My 1972 185E just feels normal. Perhaps it felt heavy when I was first getting comfortable with the plane, but now? Heck, it's just my plane. Feels right. Not heavy or 'truck like'. I jump back and forth between the Husky and the 185 and don't even think about it. Both planes feel normal to me. The new wing Husky was once incredibly light in roll, especially coming from a supercub, but I don't notice it really or compare the difference in roll to the 185. Because of my familiarity of each plane, their characteristics have become unnoticeable.
Last week I rented a 172 down south and was swinging the nose back and forth with my feet because the rudder was so much lighter than either the 185 or the Husky AND I was not familiar with the plane's handling because I hadn't flown one for 14 years. But after a few stop and goes, I fell back into the saddle with the plane in which I previously had so much time. It quickly became normal.
In another anecdote to further drive home my point, I flew a Super Cub for about 8 years. Loved that plane. Guess how it felt? Totally normal. Was it heavy in roll? Didn't notice. Then, after flying a new-wing Husky for 5 years, my friend invited me to fly his Super Cub. I told him something was wrong with the plane because the plane was so heavy in roll. The ailerons basically didn't work. My arms hurt trying to fly it. I SWORE something was wrong and told him to get his plane examined. He told me I had been flying the Husky too much. I was incredulous. So I flew a different cub. Guess what? Apparently, if you haven't been flying a cub for a while, the ailerons are incredibly heavy.
So, all that to say, light? heavy? For this class of aircraft, about 90 percent of the control feel is going to become normal to you over time. Yeah, some planes are going to be exceptional in some area, either good or bad. But if you are looking at a Cessna or some other common plane we all fly into the back country, they go up when you pull back, go down when you push forward....you get the picture. Whatever the plane, after 1000 hours, it's gonna feel normal.
Oh, and for the comparison between a 180 and 185 on gas, I fly an injected IO-520D with GAMIs and get 120 kts on 29" AK bush wheels and a baby bushwheel (these actually slow you down) on 11 gph. I don't think flying a 180 saves any gas.
Squash offline
Troy,
You should fly a T-6, wonderful flying airplane!
185 gets better miles per gallon at the same speed than a 180.
I like and agree with what Squash wrote above.
Troy,
I have flown one but it didn't seem on the par of the Stearman or beaver as far as how the control pressures and controls feeling perfect...but I agree it flies great.
Troy Hamon offline
In the past I have owned a 55 180 and a 60 C model 180 on which we put a Sportsmans kit. The old 55 was basic standard but always out performed the 60 model, it was just a great flying machine.
Also have owned a 74 and 81 185, they performed very similar although I put a slightly bigger, 84" 401 on the 81 and it was a tad better than the 74 with a 80" 401.
The best by far was a 63 185 with an IO-550 and Hartzell Buccaneer prop 82". It was quite light and went like a rocket. It was owned by a friend of mine and I hired it for a while.
Got to love all 180s and 185s, a special aircraft.
scott185 offline
Great replies - the two types (early 180 and 185) seem to occupy a similar price neighbourhood. Which is around $50k plus above a 170.
Using 500 lbs payload and standard fuel the early 185 clocks in at 10lbs/HP, while the 180 is around 11-12lbs/HP. The 170 at 15lbs/HP.
Using the excess power available equation the early 180/185 comes in at around 25lbs/excess HP available for climb, vs 50lbs/excess HP for the 170.
The ability to climb easily at 500 fpm plus at DA above 10,000’, sets the 180/185 in a different bracket of versatility which must be reflected also in ski/floats operations.
The 170 seems ideal if mainly below DA 8,000’, VFR, and gentle ski conditions.
The early 185 comes with improved loading over the 180.
L18C-95 offline
Aircraft: Piper L18C-95
L18C-95 wrote:The early 185 comes with improved loading over the 180.
Not sure what you mean by this?
Also, frankly, there are so many different mods for all these aircraft, and weights can be all over the place in individual planes, that apples to apples can be hard to get to.
But, if your plan is to strip one down and optimize performance......
Then you run into things like, is it worth it to remove a Horton STOL kit and replace with a Sportsman? There’s no doubt in my mind that the Sportsman is a better kit, but are you willing to go there? And there are many other mods (flap gap seals-duh!) that are pretty common on these old airplanes.
Point is, it’s really hard to find an all original plane of these types.
I know everyone raves about the Sportsman, but a Horton STOL equipped 180 running one and a long prop has won Valdez a few times and other competitions up here as well.
My plane has the MASA kit on it and it will stay.
akaviator offline
Aircraft: TBA
Which is my point......and I’d do the same.
I have owned both, a 58 Horton equipped 180 and now a 73 Sportsman equipped 185.
They are most certainly different airplanes. You can't fly the 185 like a 180, doesn't work.
The 185 is heaver and more of a hand full on a windy crosswind day.
That said I do love the additional weight charring capacity and the 185 will true out at 160 mph on 13gph which is better mpg that the 180.
Tom
a3holerman offline
Aircraft: Cessna 185
akaviator wrote:…..My plane has the MASA kit on it and it will stay.
Do you know what MASA stands for?
I'm curious if it is / was the same kit as the Mid America STOL kit.
Of the old kits, I like the Owl STOL kit best--
mainly because I just like their owl logo. :roll:
Yes, MASA is Mid-America STOL. I don't believe there's a whiskers difference between Owl, Bush, Horton, or the MASA.
I do know that with two folks and half tanks she get's off the ground with authority. 82" McCauley.
akaviator offline
Aircraft: TBA
Haha I would sure hope so
Interesting topic. I operate a 59 180 that was stock but I’ve upgraded to Sportsman’s, WingX, and Pponk 0-520; a 63 185 with IO-520; and a 75 185F; plus have a smattering of time in other skywagons. The 59 180 and 63 185 fly very similar, but the 75 185 feels A LOT heavier on the controls. It feels like a different aircraft. I’ve flown a 73 180 that was somewhere in between. Most of it is perception, but the 75 185 is also ~500lbs heavier empty than the 59 180. It will still haul more legally. After flying the late 185 the early planes feel almost toy like in handling. After flying a 206, the late 185 does. After flying any of them for a bit they feel normal. Go figure. Kinda like driving an F150 vs F250 camper special.
For my $ an early 180 or 185 kept light and close to stock is about as good as it gets for a sweet flying heavy hauling personal or light duty bush plane.
For a real honest to God >500hr a year working plane - a late model 185 (or 206) moded for the mission is the way to go. Mine is heavy with lots of extra fuel and avionics for aerial survey, AK-HUNT’s is stripped almost as light as an early model with great performance and load hauling ability.
But in any case, for a personal plane, get the best deal (not cheapest), best flying skywagon that you find within your budget and you will grow to LOVE it!
North River offline
I have flown 7 different F model 185s. Perhaps more, but my quick mental count came up with 7. Three of those have the same set of 4 mods: WingX, Robertson, Sportsman, and VGs. Those three airplanes all feel very different from each other despite being the same in terms of installed wing mods. The others all sport various levels of zero to some of those mods, and as you might guess, each of those also feels different.
They all feel different, but I would buy any of them in a heartbeat if I had the funds to pull off the purchase.
Troy Hamon offline
Ping to bring this topic back up.
So I have owned a 1963 185B for the last 12 years, my fist and only skywagon. It has the IO-520, 88" Black Mac, VG's and the old OWL cuff. On 8.50's is weights 1829 empty with a useful of 1,370lbs. I mainly fly on Floats, EDO 3430's putting her at 2,137 and a useful load of 1,212lbs. Wing-X would take her to 3,525 which I don't have but would be a great upgrade if the legal useful load was needed. I have about 1,000 hours in this particular 185.
This brings me to my dilemma.
My mission profile is changing, kids are grown and off to school, St. Bernard is sunsetting, cabin is built and so on. I have the opportunity to sell the 185 (extract some equity and pay down some debt) and buy 1/2 of a 55' C-180 with the O-470R that my friend owns. I've been business partners with him before and he has another aircraft that he flys most of the time. My intent would be to add an experimental cub to the mix in a few years.
The 180 has Wing-X and Sportsman's cuff on EDO 2870's. Just over 1,000 lbs on floats of useful which should get the wife and I to the cabin with plenty of weight to spare for weekend supplies. I have not flown the C-180 yet but from the research I've done, everyone keeps saying how they are lighter on the controls. I've watched 180's with the wing mods get off the water faster than my 185 with similar loads. I fly ROP at sea level at 16gph where the 180 is closer to 13gph.
Will I have many regrets of selling the early 185 and getting into a partnership on a early 180? Thank you for your thoughts.
Chris
N2577Z offline
Aircraft: C185B
Unless you really need the cash your taking quite step back. On wheels no big deal but a 185 on 3430's is about as good as it gets in the float world. The Edo 2960's weren't approved until the 1964 G model 180 so you might want to check on that for some other approval. 55 was approved on 2425's and 2870's. Only about 3.5 hours fuel on a 55 180. Resale on those old 180's is not the best in a normal market. None of the 180's I had would come close to the performance of a 185. Could go on and on but I think you would regret that move.
peterdillon offline
Aircraft: Floats
I agree with Peter's comments (above post). The 3430 is a great performing float and provides the greatest bang for the buck for 185 float ops, (there is also one late model180 on 3430's, Ward Air). Although the O-470R is one of the greats in the opposed engine class, there is no replacement for displacement when it comes to float operations, I speculate you will be disappointed stepping down based on power available alone.
TR
TR offline
Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
Re: early 180 vs 185, I agree with both above comments. The 2960s are great floats, once you learn to fly them. I'm not sure there is an approval for the earlier 180s, though. The 2870s work fine on those planes, especially with an inch cut off each aft float vertical strut.....
The difference in useable fuel may also be important, depending how far you have to go to said cabin. Weather diverts, etc can frequently make one wish for more gas.
But, frankly, it'd be hard for me to give up a good 185 that I know well (and you obviously know that one) for a mid year 180. They are both great airplanes. But, again, that 180 is an unknown quantity, whereas your 185 is less so.
