jrc111 wrote:I'm afraid it's a liitle worse than you've indicated for us early 180 owners. Per AD 75-16-01:
http://www.airweb.faa.gov/Regulatory_an ... enDocument
which references SE75-7:
https://support.cessna.com/custsupt/con ... s_id=25704
which in turn references "Chart 1":
https://support.cessna.com/custsupt/con ... s_id=25705
which results in having to subtract 2 gallons from the total and useable fuel quantities for each fuel bladder which has been replaced with a a fuel cell with a date of manufacture after 1973. So, for my 180B, that works out to 51 gallons useable.
When I calibrated my EI CGR-30P with the aircraft leveled, the right tank held 28.6 gallons till empty, and the left 30.0 gallons. That's level, and not in a landing or stall AOA. To figure that out, you'd have to mimic that AOA by raising the main gear and digging a hole for the tailwheel, which was more effort than I was willing to extend.
180driver wrote:In my '59 Cessna 180 nearly all of the 32.5 gallons in each tank is usable in level flight. In these early models there is only a single fuel pickup on each side, towards the middle of the tank so when you are three point you can have 7 or 8 gallons in the tank and not be able to get it to your engine (especially with big bush wheels and a small tailwheel) If you leave the fuel selector on both and burn 4+ hours you will get on the ground and the engine will quit when you lower the tail. My practice is to run one tank dry the last hour of a four hour flight so I know I have enough in the other tank to taxi off the runway when I get there.
180Marty wrote:I've heard if you put it into a little bit of a side slip you can force the gas up against the outlet side of the tank and get more out.
soyAnarchisto wrote:This is not good news. I read through this rather quickly. Must we reduce the _usable_ capacity by 2 gallons? Per side?
That's not cool.
B) On all models of aircraft manufactured in and prior to 1973 review the aircraft records to determine if new fuel bladder(s) have been installed since June 1, 1973, and if so, comply with Paragraph A of this AD unless it is established that the fuel cells installed were manufactured prior to June 1, 1973, and this fact is entered in the permanent aircraft records.
NOTE: The owner may review the aircraft records and if he determines that new fuel bladder(s) have not been installed since June 1, 1973, may enter such information in the aircraft records.
mtv wrote:Frankly, asking someone else how much fuel is available in their pretty old airplane doesn't do you a lot of good. As noted, there are Cessna bladders, aftermarket bladders, and sometimes other issues that can affect the useable.
PLANNING on using a side slip to get fuel out of a tank is a fool's game, but it's good to know if you really screw the pooch sometime.....but far better to NOT screw the pooch in the first place.
Get the airplane leveled on it's main wheels, with the tailwheel up on a barrel or sling, etc, to get the airplane into a level flight attitude. Before you do this, run the fuel down to minimum you're comfortable with. Open the gascolator drain and drain both tanks with the fuel selector on "Both".
Now, get the airplane to a pump with a certified meter, and fill it up with fuel. THAT is YOUR useable fuel. Granted, you may be able to get a little bit more out of it by fussing with it, but this should give you a good baseline.
But, bear in mind, that's the useable fuel in level flight, NOT maneuvering. So, get the fuel level down to that point, then descend/climb or maneuver at your own peril.
Frankly, I've never liked bladders because there can be a little variable to a lot of variability in their capacity.
