mtv wrote:The military harnesses I've used were designed to lock because (at least the ones I used--not many, by the way) weren't self locking (in other words they weren't inertially locking) harnesses. The only way those locked up was if you locked them.
All of the ones that I'm familiar with are either or, that is they will always lock on inertia, you can't turn that off, but if you want to you can manually lock them. "Shoulder harnesses - lock" was in most emergency landing checklists.
USAARL, United States Army Aeromedical Research Lab tests pretty much determined that a four point harness wasn't much if any better than a three point because you submarine a four point so easily. Apparently in a crash sequence the seat either deforms or at least the cushions squash and your body shoots out underneath the seat belt. With a five point harness this doesn't happen. It doesn't help us of course, but the greatest safety thing in the newer helicopters is a seat that "strokes", that is it collapses in a controlled manner, gradually decelerating the crew member and absorbing energy as it does.
Like it or not a properly designed helmet is at least as important as stroking seats and five point harnesses too.
Oh, and another thing I thought was interesting. With the crash dummies USAARL found that something they called "rebound overshoot" was a killer. What that is, is if you tighten your shoulder harnesses to the point your back is bent over, during the crash sequence it is likely that your body will be thrown back against the straps when you rebound and this can break your back, so ensure your shoulder harnesses aren't so tight that you can't sit straight up in the seat.
