Thought I would stir the pot??
https://www.savvyanalysis.com/articles/egt-myths-debunked
Squash wrote:Why would you think that posting this would be pot stirring? Knowing what EGT is and isn't is one of the steps to becoming an educated pilot. It probably doesn't matter to those who fly with single probe instruments. But it is common knowledge for those who fly injected engines LOP with multi-probe engine analyzers. No pot stirring in that link....just plain Jane education. I took the Advanced Pilot Seminars online course 4 years ago and am a believer in the benefits of LOP operations. I think my savings to date exceed $10,000. Wow, that was some serious thread drift. Sorry Zane.
Hammer wrote:And the lead buildup from running cylinders too cool can be more damaging to valves than running them too hot. The valves' primary cooling mechanism is the heat transfer to the valve seat when it closes. If that connection between the valve and valve seat is interrupted by lead build up, then the valve dissipates heat poorly and unevenly, so that at even low EGT's the valve can overheat and be damaged.
The multi-probe EGT also lets me select the throttle setting which will allow me to lean without any cylinder getting too hot or too cold...no burning, no lead build up. There's a very specific spot on the throttle that allows that, and any other throttle setting will produce very large EGT spreads. The author states there's no benefit to equalizing EGT's, but I don't agree with that. If you can run all your EGT's at the same temperature, you can lean so as to prevent lead buildup or overheated valves in any cylinder. Granted, you could accomplish the same thing without using absolute numbers, but the point is running all the cylinders at the same EGT has advantages.
a3holerman wrote:Back in my 180 days I was told the way to run the throttle, when high enough, was to back off from full to the point where you just saw the MP gauge start to decrease then in a bit. The theory was that this cocked the butterfly in the carb just enough to create enough turbulence to help the fuel atomize better.
Tom
