§ 91.21
Portable electronic devices.
(a) Except as provided in paragraph (b) of this section, no person may operate, nor may any operator or pilot in command of an aircraft allow the operation of, any portable electronic device on any of the following U.S.-registered civil aircraft:
(1) Aircraft operated by a holder of an air carrier operating certificate or an operating certificate; or
(2) Any other aircraft while it is operated under IFR.
(b) Paragraph (a) of this section does not apply to—
(1) Portable voice recorders;
(2) Hearing aids;
(3) Heart pacemakers;
(4) Electric shavers; or
(5) Any other portable electronic device that the operator of the aircraft has determined will not cause interference with the navigation or communication system of the aircraft on which it is to be used.
(c)
In the case of an aircraft operated by a holder of an air carrier operating certificate or an operating certificate, the determination required by paragraph (b)(5) of this section shall be made by that operator of the aircraft on which the particular device is to be used. In the case of other aircraft, the determination may be made by the pilot in command or other operator of the aircraft.
This is the stickler! No one wants to bear the responsibility of saying it's OK, Tho now you can use wifi if you buy it and you can use your cell on Virgin. Also if your pilot says OK you can use it??!!Lots of people used them on 911 and also when they dunked the jet in the Hudson!! looks like they are dangerous as those were all wrecked!!
Makes you wonder how your GPS and Sirius works in your own plane??
Kinda like the 60 year rule for 121 pilots that was raised to 65, or the difference between the 2nd and 3rd class medicals and then the sport pilot?? Someone said this is what it is and so be it!!
So everyone who is using you portable non IFR certified GPS with weather and radio while IFR!,
( YOUR BREAKING the RULES!!!)GT
