onefitty wrote:PAMR MX wrote:I would bet ya a beer both magneto condensers are bad.
Yup, my money's on condensers and / or points
onefitty wrote:Most make TBO and beyond, but occasionally they fail... We've had condensers fail in less than 10 hours and points misaligned, burnt and occasionally not installed correctly. We used to do mags in house but now send them out due cost, maybe not a good thing...
If cost is an issue, can you borrow a set of mags to try? Only a couple hours to swap over
BlackWater wrote:Wow, that sounds like detonation! ...
Barnstormer wrote:BlackWater wrote:Wow, that sounds like detonation! ...
My vote as well, especially since it had two cracked pistons and rings before. Initially reaches full rpm then as the detonation starts rpm drops because of premature/uneven firing. Sure sounds like detonation to me.
PAMR MX wrote:Awww the old weak valve springs. I will put a beer in the mail.
Newbizor wrote:So today I put all new valve springs in it and took it out for a run......No more vibration or big RPM dips at full power. I am still getting about 50ish rpm swings on the tach but I cant feel or hear it, if I sat there with my eyes closed I wouldn't know the tach was swinging, the bouncing of the needle seems to coincide with the movement of the airplane in the wind so I really think this problem might be solved!
I ran around town this afternoon looking for a digital tach of some sort so I could confirm the needle movement on the tach is just the tach itself but my search was unfruitful. Either way I'm going to cowl it up and take it for a spin, this thing was bucking like a bronco before on takeoff, you could feel/hear it very obviously so I'll know right away that the problem is fixed for sure. I'm going to try and get it up tomorrow, the weather is supposed to be better. I'll post my results.Barnstormer wrote:BlackWater wrote:Wow, that sounds like detonation! ...
I would like to add, there were actually 4 cracked pistons, but the cracks were radiating from the holes in the oil control ring (below the pin) down to the bottom of the skirt, one crack on each of the 4 pistons in exactly the same spot... The cylinder with the broken rings had a bit of surface rust inside it when I bought the plane. Before I purchased it it had maybe 20-30 hours put on it since 2011, and before that it had been sitting since 1989ish. There was no indication on the tops of the pistons or anywhere else of stress/melting/cracks that I would associate with detonation.
cliff wrote:Your engine didn't happen to be bought from a guy in PA on Barnstormers? If so I know a little bit about the engine. I am just wondering because the years of non use and low hours sound the same.
lesuther wrote:Wow...thanks for the update. I've never run into a spring issue before. It's an education for me for sure.
Thanks!
hotrod180 wrote:IMHO this is where a good engine monitor / multi-point EGT / CHT gauge would really earns it's keep, isolating problems to a certain cylinder(s) for diagnosis purposes.
