Backcountry Pilot • Engine mount advise
Engine mount advise
12 postsPage 1 of 1
Engine mount advise
My buddy just got the bad news his engine mount is cracked. We are wondering if its better to just get it welded or upgrade to a new/better one. Any recommendations? Thanks
gassman offline
Aircraft: Mx7-180
Re: Engine mount advise
What is the condition of the mount otherwise? Is it 70 years old or 40? Is it now being used to hold a much higher output engine than was originally installed on it? Is there signs of internal corrosion? Is your friend interested in potentially having a smoother less vibration prone operation?
I usually lean towards replacing the mount with new myself, these questions might help make that decision.
Halestorm offline
Aircraft: C-182E Pponk
Halestorm wrote:What is the condition of the mount otherwise? Is it 70 years old or 40? Is it now being used to hold a much higher output engine than was originally installed on it? Is there signs of internal corrosion? Is your friend interested in potentially having a smoother less vibration prone operation?
Agreed and on top of that would be which mount is it? Cessna made several improvements over the years - I would not even mess with some of the earlier ones - the ones with out the two side vertical tubes.
This is a good read on the Cessna engine mounts (not very long), I'm not pitching the seaplanes west mount - just providing it for some info on the older cessna mounts.
https://www.acornwelding.com/seaplanes-west-stc-engine-mounts
corefile offline
Aircraft: Cessna 180 - sold
This is a good read on the Cessna engine mounts (not very long), I'm not pitching the seaplanes west mount (but that is what I went with, but I upgraded to a Pponk and 3 blade prop and I had the older engine mount with out the vertical tubes ) - just providing it for some info on the older cessna mounts.
corefile offline
I have a C185 mount in the pile of "hangar sale" stuff I've been meaning to list for sale. I know nothing about Cessna's' so maybe it in not applicable or worth considering putting a C185 tilt down mount on a C180.
Thanks whee, ill let him know.
gassman offline
Aircraft: Mx7-180
I have a tilt down 185 mount on my 180, heavy duty mount. But, the engine is about an inch or so farther forward.
StillLearning offline
Wow! Forgot to mention its on a 66 c185 with a 520 and 3 blade mac
gassman offline
Aircraft: Mx7-180
IF it is fuel injected, I have a SeaPlanes West mount that might fit in my “Hangar Sale” pile. If he is interested I can find the part number?
PNW Flyer offline
Aircraft: C182P
PNW Flyer wrote:IF it is fuel injected, I have a SeaPlanes West mount that might fit in my “Hangar Sale” pile. If he is interested I can find the part number?
Wide body 182 mount won’t fit on a 185 unless you get out a cutting torch.
Halestorm offline
If that mount fit in a 185 it wouldn’t have made the trip to Seattle! :D :D
Pinecone offline
Come to find out it was the original mount for 470 with 2 blade prop. Seaplane west ordered.
gassman offline
Aircraft: Mx7-180
12 postsPage 1 of 1
