Backcountry Pilot • EZFlap Handle Review
117 postsPage 3 of 61, 2, 3, 4, 5, 6
Re: EZFlap Handle Review
He took a lot of time to shorten it at the quadrant end and make it look original. A nice job complete with distressed paint. Not sure that there was any basis for approval:) Someone would have to be extremely observant to see it.
daedaluscan wrote:He took a lot of time to shorten it at the quadrant end and make it look original. A nice job complete with distressed paint. Not sure that there was any basis for approval:) Someone would have to be extremely observant to see it.
Having gone to the trade shows and talking to pilots all over, I got to hear several hilarious stories about how others solved this problem in the past. One guy had a section of a dog's leash he tied to the flap handle and the loop end was velcro'ed to the panel. Another guy took great pleasure in showing me how he figured out that he could use his right foot to hook under the thumb button, depress the button, and raise the handle. When I asked how he maintained directional control of his 180 in a crosswind with one foot, he finally admitted he hadn't actually used this technique in practice. Then there was the guy who said he carried a length of half inch dowel rod and a little nylon pocket taped to the end.
I would completely agree with daedaluscan that a shortened OEM Cessna flap handle would be difficult to spot. Most of the ASI inspectors out in the field today would not pick that up. The paradox would be that if you shortened it up enough so that it was really more convenient to reach, then it would not give you enough leverage to operate the flaps over 60-70 mph. If you left yourself enough leverage to operate the flaps above that speed, the flap handle would still be far enough away that it would be a PITA to use (That's why the better solution was vertical more than horizontal).
EZFlap wrote:.... I got to hear several hilarious stories about how others solved this problem in the past. One guy had a section of a dog's leash he tied to the flap handle and the loop end was velcro'ed to the panel. Another guy took great pleasure in showing me how he figured out that he could use his right foot to hook under the thumb button, depress the button, and raise the handle. ....Then there was the guy who said he carried a length of half inch dowel rod and a little nylon pocket taped to the end.....
While I don't see the need for an EZ Flap, I can understand why others might like them.
But I find it hard to believe that anyone would do the dog leash/right foot/dowel things as described.
An EZ Flap is sure better than any of those.
hotrod180 wrote:While I don't see the need for an EZ Flap, I can understand why others might like them.
Thank you :)
I hope one day all of the people on the forum can sit in an airplane that has this installed, and decide whether it makes a worthwhile difference versus a dog leash. It just breaks my heart to think that a dog might get lost somewhere because the owner used the leash for his flap handle :wink:
I bought a handle from EZ Flap a year or so ago and really like it. The primary reason was financial, and the performance benefits are an added bonus.
My Stinson only had lap belts in it when I bought it, so I wanted to upgrade to shoulder harnesses for all four seats. I was able to buy four sets of Wag Aero shoulder harnesses and an EZ Flap handle for less than the cost of two BAS harnesses. Even with the BAS harnesses, it would still be a stretch to reach the flap handle in the retracted position and keep my eyes looking over the nose with stock 7.00x6 tires, let alone anything bigger.
So in the end I saved some money for gas, can have my whole family belted in as safe as possible, and don't have to take up yoga to reach the flaps and keep my eyes out of the plane at the same time :D
My one criticism is the trigger location on the Stinson/PIper style handle, but I've gotten used to it. I still need to return the drill jig and paperwork :oops:
1:1 Scale offline
Aircraft: Maule M4-220C
Kelly
Maule M4-220C
An EZFlap arrived at the house today so it went into the Bearhawk. Pretty easy install for the most part, except for having to make two trips back to the house to get tools that weren't at the hangar.. I haven't flown with it yet, but it sure is nice not to have to bend over to grab the flap handle! Here are some photos with it installed:
I'll report back after a few weeks of trying it out.
blackrock offline
Aircraft: Bearhawk
So looking at the EZ flap handle in the pics above, I'm having a hard time picturing how you use the flap handle regularly when it is pulled up. The handle is in the way. Or am I just really dense and not seeing it correctly? I know for sure from the pictures that the EZ handle is too high to pull full flap the way I sit in my 180.
P.S., not knocking the product at all, just very curious.
The one in the photo (Bearhawk) is a completely different shaped unit, and different control/seat geometry, than your 180. Totally different. You can see the Cessna unit in use easily in the little video on the product website.
On the Bearhawk/Stinson/Maule/Piper, you almost never have to use the original flap handle (although it is still 100% functional). On the Cessna installation you will be using both the EZ Flap and the OEM Cessna handle equally. This is because Cessna uses a much longer tube and a 2 to 1 movement ratio (to get enough leverage to pull big flaps against big air loads).
Yes the EZFlap is not convenient to reach at full flap in a 180. It's not supposed to be. When installed correctly on a Cessna, at 30 and 40 degree flap deployment the EZ Flap unit is between your elbow and your rib cage, and you are holding the OEM Cessna handle in your hand. You won't "bump into it" but you will move your hand past it closely. This only takes a few cycles to get used to. At 0, 10, and 20 degrees you are holding the EZ Flap handle and un-lock trigger... and the OEM Cessna handle is out of your safe reach 8)
Another important point is that a lot of pilots have the seat way too far forward in their 180's, most of which is because they want to be able to get to the flap control. I've seen people run the seat so far forward they can't get full control movement on the yoke. This is really unsafe, regardless of everything else. In most cases, these pilots can move the seat rearward (allowing more comfort and full safe control), because the EZ Flap brings the flap control within reach of the pilot. The other reason pilots go forward too far in a 180 is to try and see better over the nose aftr installing big tires. Moving the pilot upward (seat cushions, articulated seat) gives them back more of the lost visibility than moving forward. But upwards also means that the original flap handle is further away. So they choose the wrong, less safe solution. All that gets solved the safe way with the extension installed.
EZFlap wrote:...Another important point is that a lot of pilots have the seat way too far forward in their 180's, most of which is because they want to be able to get to the flap control. I've seen people run the seat so far forward they can't get full control movement on the yoke. .... The other reason pilots go forward too far in a 180 is to try and see better over the nose aftr installing big tires.....
I call bullshit. I think most people move their 180 seats forward to be able to comfortably reach the rudder pedals. When you get the seat set so that you can reach the pedals, the yoke is pretty close to your torso if you're built "over square". Reaching the flap handle is a separate issue IMHO.
Depends entirely on the geometry of the pilot.
A pilot with really long arms and really short legs might move their seat too far forward primarily in order to reach the rudder pedals. Another pilot with long legs and shorter arms moves the seat forward to reach the OEM flaps even though he can easily reach the pedals. An average pilot might move the seat forward too far because of wanting to see over the nose with his Bushwheels. I've spoken with all of them, and then some.
Bullshit is definitely one of my skills, but I was not using it in that post. For people with too much time on their hands, a better demonstration of that skill is here: http://www.grantstar.net/sales-materials.html
blackrock wrote:I'll report back after a few weeks of trying it out.
Look forward to reading your review.
EZFlap wrote:The one in the photo (Bearhawk) is a completely different shaped unit, and different control/seat geometry, than your 180. Totally different. You can see the Cessna unit in use easily in the little video on the product website.
Thanks for the explanation. As I said I was not trying to put your product down. Guys on here that I trust use it, and that's good enough for me. I was just curious. I'm one of those guys that needs to be further ahead to reach the rudder pedals comfortably. But at 150 soaking wet, there's still room for the yoke.
Your product is on my list of mods, but it's a little ways down. One day I'll make it there though.
EZFlap wrote:Another important point is that a lot of pilots have the seat way too far forward in their 180's, most of which is because they want to be able to get to the flap control. I've seen people run the seat so far forward they can't get full control movement on the yoke. This is really unsafe, regardless of everything else.
I'm sorry, EZFlap, but this argument doesn't hold water. There are other reasons to choose your product, but sitting full forward in a 180 is not unsafe. The main argument I can see for the EZFlap in a 180 is to be able to go from zero flaps on takeoff without having to bend forward. This has very little to do with seat position.
Personally, I start my takeoff roll with 20 degrees and can easily "pop" them for short take offs without reducing safety. The small aerodynamic advantage I would gain by starting my takeoff roll at zero flaps isn't a priority for me, but I'm just a weekend warrior, not a STOL champion. :D
Sitting far enough forward that you do not have "full, free and unrestricted" movement of the main control yoke is unsafe. Period. With or without anybody's flap controls, rudder pedals, instrument panels, seats, or seat belts. Some people can sit all the way forward in a Cessna and have free movement of the yoke, some cannot.
One of the (many, various, diverse, numerous) reasons that people move their seat too far forward is that they otherwise cannot safely or comfortably reach one or more of the controls.
We should get back to the original purpose of the thread (actual reviews)... otherwise the forum admin will rightly point out that the technical validity arguments belong in another (previous, blood-soaked) thread, and I'll cheerfully point out that the validity issue has been proven out in the field :)
I think you'd better quit while your ahead bro... The BS is starting to get pretty deep....
Nothing has been "proven" here other than some folks are good at biting their lips...
www.avthreads.com
I'm ahead because I didn't quit. Make no mistake.
Quite a few things have been proven here regarding this particular subject, if you care to read through it all.
I'm with you here. I always start with at least 10 flap and can easily reach the handle. This is why the mod is down on my list. Would still be interesting to try one day though.
bigrenna wrote:I think you'd better quit while your ahead bro... The BS is starting to get pretty deep....
Hafast offline
bigrenna wrote: but it seems to me this is adding a "solution" where there is no problem.
The same could be said about 99.999% of the Bushwheels I've seen running around the lower 48 :wink: and to think some owners will even try multiple styles and sizes on the same pavement pounding plane #-o
I say good on Bill for having the nuts to stand up to all the FAA bull to see his idea through STC, and then have the nuts to deal all the BS people who have never used his product will dump on him.
Rob offline
100% agree with you Rob.
I don't personally know 99.9% of the people on this forum but I still try to respect everyone's opinion. Having said that, I highly doubt there is any product made that will satisfy everyone. If you buy something and don't like it, I understand. But there are also those that find a product perfect or almost perfect for them and couldn't be happier. No reason to condem or ridicule it just because it 'isn't for you'.
Heck, there are people that even like rap music so much they buy it, that ought to tell you something!! I personally have no use for it, but I doubt I will get on forums and tell others not to buy it since I don't see the need for it. Damn, I am really rambling this morning....I need to go do something constructive.
