If you smash up your plane are you required to report it to the FAA. How about if you taxi plane into an irrigation ditch, break the nose fork and bend up the prop. Just asking. Guess that is a prop strike though.
"Substantial damage means damage or failure which adversely affects the structural strength, performance, or flight characteristics of the aircraft, and which would normally require major repair or replacement of the affected component. Engine failure or damage limited to an engine if only one engine fails or is damaged, bent fairings or cowling, dented skin, small punctured holes in the skin or fabric, ground damage to rotor or propeller blades, and damage to landing gear, wheels, tires, flaps, engine accessories, brakes, or wingtips are not considered "substantial damage" for the purpose of this part."
Glidergeek wrote:I think there is something to do weather you were taxiing to take off or land? If you were just taxing to reposition on the ground not intending to fly or coming from the runway after landing?
aktahoe1 wrote:Sounds like more than $25,000 in damage. Yep you must report. FAR/AIM, AIM section 7-6-2. Also look at CFR 49 830.2...after yesterday, this shit is fresh in my head! I still feel like this after my oral...![]()
L-19 wrote:I don't like the sound of that... Hope it wasn't you."Substantial damage means damage or failure which adversely affects the structural strength, performance, or flight characteristics of the aircraft, and which would normally require major repair or replacement of the affected component. Engine failure or damage limited to an engine if only one engine fails or is damaged, bent fairings or cowling, dented skin, small punctured holes in the skin or fabric, ground damage to rotor or propeller blades, and damage to landing gear, wheels, tires, flaps, engine accessories, brakes, or wingtips are not considered "substantial damage" for the purpose of this part."
Sounds like yes, but it's your interpretation of how bad the damage actually is. Sounds like a major repair from what you said.
Jaerl wrote:I thought that if ya post it on here, you did report it to the FAA.
Super-Maule wrote:If there is no intent of flight, the accident reporting requirements of NTSB 830 are not necessary and the FAA does not need to be notified.
The horses mouth
bumper wrote:Gaawwwley! And here all this time I though it weren't reportable if it happened close enough to your hangar so you could quickly push all the parts inside and slam the door shut.![]()
Seriously, I heard a story about a Husky owner who lived at one of those fly-in communities. Just got the plane brand new and bounced it hard on landing whilst getting checked out, tried to go around but screwed that up to, stalled, balled it up, came to rest upside down. Shoved it and the pieces all into his hangar and said not a word.
I mean he does.
hicountry wrote:What happens if you ball it up IN the hangar?
