Backcountry Pilot • FAR's ?
FAR's ?
20 postsPage 1 of 1
FAR's ?
Hello Folks, Have been kinda on the sideline for awhile!
Had a problem with my new amphib, kinda tore it up on a hard landing in the middle of a take off from a paved strip, Good thing is I walked away!
Had to make a choice of ruining the aircraft or maybe keep it running long enough to miss most of town, if it quit, I had full tanks. Lots of houses in the way.
I had a bit of a curfluffle with the the local city officer.
I ended up handcuffed arrested and booked for not giving my license and medical to him.
I actually was handing it to him when he asked me about the accident, I told him I was not going to answer his questions about that. He got a little hot under the collar after I told him that a couple of times and when I started to walk away I ended up against his car with handcuffs on and a Taser stuffed into the middle of my back. He at that time took my pilots license and medical from me and I went to jail. This is after I was done with the FAA and NTSB and they had released the aircraft to me. After I bailed out of jail I went back up and got my aircraft off the runway which had been Notamed closed.
I did get my license and medical back when I got out of jail.
1 question for any experts on the word of law is ' the word in the FAR's is present? Does anyone have knowledge of a court case where that word is defined?
2 is there any statute ur rule that snout there that allows a police officer to take a pilots license or medical from them?
Thanks GT
Also anyone have an early 182 with no interior and an engine in it that will make one ferry flight?
GT
M6RV6 offline
Re: FAR's ?
Take a gander at 14 cfr part 61.51 (i) (iii)
Presentation of required documents.
(1) Persons must present their pilot certificate, medical certificate, logbook, or any other record required by this part for inspection upon a reasonable request by—
(i) The Administrator;
(ii) An authorized representative from the National Transportation Safety Board; or
(iii) Any Federal, State, or local law enforcement officer.
If he requested it then you are required to present it for inspection...does not mean that you have to surrender it to him and he does not have the authority to keep it. He must reasonably request it and can only keep it a reasonable amount of time to inspect it for whatever he is looking for. In the case of a logbook this can be a few hours...in the case of a license and medical it should be no more than a few minutes as there is not anything to look through on either document simply what is printed on the face.
lowflybye offline
Re: FAR's ?
George sorry about your run in with Barny Fife :roll: -We have extra parts Straight tail with engine. I sent message to your phone --- Bill Reid
182 STOL driver offline
Re: FAR's ?
Ditto on what Lowflyeby said. There was an article in AOPA Pilot magazine some time back regarding this, written by John Yodice, AOPA Chief Legal Counsel.
Local police do have the authority to inspect your license/medical, but even the FAA does NOT have the authority to keep it, without a "legal process".
Re: FAR's ?
Thanks guys,
I'm familiar with the far on presenting you documents.
Maybe I didn't phrase my question right.
I was wondering if someone had a legal definition of present?
The other was is there any statute where a officer can take it from you with threats of bodily harm.
Or even with out threats.
Just trying to get some info. As I am going tom have to go to court on this!!
Yes I am a AOPA member and I donate to the legal fund.
Just tying to find someone that has been there.
GT
Thanks again.
M6RV6 offline
Re: FAR's ?
M6RV6 wrote:Just tying to find someone that has been there.
GT
Thanks again.
I did not have a run in with local law, but did have a dealing with the FAA that turned out benign. My attorney in that instance told me that present for inspection meant that I have to make it available to him to inspect...if he felt the need to physically hold it for the inspection then he had the right to do so and refusing to allow him the opportunity would only cause me trouble that I did not need.
I think where you may have some ammo is that he cannot take it, only inspect it and the regulations state "upon reasonable request". If there were threats involved in order for him to obtain it that would not be considered a reasonable request. You may have a leg to stand on with the arrest as well because I am not sure if he has the authority to do so simply for failure to provide him the documents...especially once the FAA has inspected them. I may be wrong on that, but even the FAA cannot have you arrested for failure to present it. They can only request an emergency suspension of your license based on a perceived safety danger for failure to present the documents and even then it must go through legal process and be approved by the FAA legal department and signed by a judge before it is in effect. Typically you then get 30 days to provide the documents without further action.
Most of the local law enforcement officers do not have a clue as to the FAR's and make up their authority as they go along. The regs regarding a pilots license are not the same as the regs regarding a drivers license. An officer can take your drivers license and arrest you for not presenting it...not so for a pilots license.
lowflybye offline
Re: FAR's ?
George, I am glad that you are all right, but sorry about the airplane. You have had your share of bad luck lately. Next time you are near Ohio, lunch is on me - I want to hear the rest of the story!
Re: FAR's ?
To answer your question on the meaning of the word "present", it will depend on the judge, but I don't think it's a good avenue for a defense. I checked my Black's Law Dictionary, and it didn't have any law or rulings cited for usage as a verb. Given the context of the word in the statute and common practices regarding presenting identification, I think it is extremely likely that the judicial interpretation will be that "present" means "give".
When you were arrested, they should have charged you with violating some specific law. It's doubtful that they will charge you with violating the FAR's, since that's not in their jurisdiction. More likely it will be something along the lines of interfering with a law enforcement officer in the commission of his duties, or something similar. Your defense should focus on showing that the officer never had a legitimate reason to request the documents in the first place. Then, he couldn't have made a reasonable request, because there was no reason.
Sometimes the best defense is to go on the offensive. Hire a lawyer, and file suit against them for false arrest and false imprisonment. Suddenly the city council or the county commissioners could perk up and start pressuring the law enforcement agency to drop the charges if they don't have an airtight case against you.
Good luck!
kevbert offline
Re: FAR's ?
What specific code section did he book you on? And did the DA file the charges?
I ran in to this in CA when CHP threatened me with arrest for "landing an airplane in the dirt, and not at an airport." Though there is no such crime as he was wording it, and another CHP buddy of mine came to the rescue and drug him off. I was going to push the issue though, to the point of arrest, because I was hungry and they would have fed me in jail. :lol:
watkinsnv wrote:CA. passed a law mind you not the FAA, that states you can only land and take off at or on a designated airport. Lance
About 25 years ago I was down in Truckee with a buddy of mine, and we were out goofing off in a mutual friend's Citabria. We took off from TRK and headed up to the "Old Truckee Airport" which was just some ruts in the sagebrush next to I-80 where the CHP scales are now.
We spent about an hour doing bounce and go's, landing south, up and 180, land north, up and 180, and so on. As we did this, we saw a CHP (California Highway Patrol) 4X4 sittin' on the shoulder of the freeway, and just figured he was there enjoying the show, and didn't really pay much attention to him.
After about an hour we got bored and headed back to TRK. We landed, and had barely parked the airplane when the airport manager came running out all excited, shouting, "What the f*** did you two do this time?!?!" Al and I pointed fingers at each other and said, "Who? Us?" not knowing what the heck he was talking about.
"Well, there's a CHP Officer here, and he's going to take you two to jail."
Oh well, that was a new one, but what the heck. About that time our young officer comes storming out, spittle flying, eyes bugged out, just screaming about pilot licenses, airplane registration, jail and handcuffs. Quite the show. I asked quietly and politely what the problem was, and he launched into a tirade about how we had broken "the law" by landing in the sagebrush and not at an airport, and he was going to arrest us.
"Ok," says I, "what law did we break by landing out there?"
He looked at me like I was stupid or something and said, "It's against the law to land an airplane somewhere other than an airport." I asked again, "What law? Give me the code section, and regulation it comes from, that you're gonna use to take us to jail and book us with." His answer was the same... "It's against the law."
This went on for probably ten minutes, back and forth, and I was actually looking forward to the trip to jail so I could get a cup of coffee and a sandwich. But my buddy Al, who was an Alaska float pilot in the summers and TRK CFI in the off seasons, had given the airport manager the high sign to call a flight student of his, who was also a Truckee CHP officer, to get down there and help get this train wreck straightened out.
The manager made the call and Scotty arrived shortly. He listened to the story for a few minutes, looked at Al and I and rolled his eyes, then pulled junior CHP aside and had a long talk with him. Our young officer never came back to apologize to us, but just stomped off after talking with Scotty. But, Scotty came back, said, "Sorry about that guys. Kid's new, fresh up from LA, and he's never seen an airplane land in the dirt before."
Maybe there is a law on the books now, but in my experience, most non-flying cops think off airporting is against the law just because they think it should be, but when pushed to cite the actual code section, they can't.
Re: FAR's ?
mtv wrote:Ditto on what Lowflyeby said. There was an article in AOPA Pilot magazine some time back regarding this, written by John Yodice, AOPA Chief Legal Counsel.
Here is one article. I think you have to be logged into the AOPA member section to be able to read the whole article:
http://www.aopa.org/members/files/pilot ... c0206.html
A recent FAA enforcement case gives us an opportunity to review these regulatory requirements. It also gives us a real-life answer to some of these questions, especially to the "what happens" question.
Let's look at the rules. The regulatory requirements are contained in FAR 61.3(l) and 61.51(i). These regulations require a pilot to "present" for "inspection" certain pilot documents upon the reasonable request of certain officials. Yes, in answer to one of the frequently asked questions, the request must be "reasonable." While the word reasonable appears in only one of the two provisions — FAR 61.51(i) — it has been interpreted to apply to both. The concept of reasonableness is narrower than one might expect.
What documents must be presented? The credentials that must be produced for inspection are an individual's FAA pilot certificate, medical certificate, and pilot logbooks. There are other documents that must be produced, but they don't seem to raise the same level of concern. These are the records that are required to be kept by FAR Part 61. FAR Part 61 governs FAA certification of pilots and instructors. These records include special-purpose pilot authorizations such as the familiar LOAs (letters of authorization) and flight and ground instructor certificates.
The officials named in the regulations who may make such requests are: authorized representatives of the FAA, the National Transportation Safety Board, and any federal, state, or local law enforcement officer.
OK, in summary then, a pilot is required to present for inspection his or her pilot and medical certificate and logbooks at the reasonable request of an FAA or NTSB representative, or a federal, state, or local law enforcement officer.
The pilot involved in this case is a flight instructor. He was administering a biennial flight review to another pilot when the Cessna 172RG they were flying landed gear up. The local FAA flight standards district office began an investigation of the incident. As part of the investigation, the FSDO wrote to the flight instructor asking him to present his pilot logbooks and flight instructor records for inspection. (Later in the proceedings, the FAA also demanded that he produce his medical certificate for inspection.)
For what he thought were good reasons, the flight instructor refused to comply. He was familiar with Part 830 of the National Transportation Safety Board regulations, which prescribes what accidents and incidents must be officially reported. This was not one of them. Since the involvement of the FAA was not required or invited, according to the flight instructor, he concluded that the FAA request was an unreasonable invasion of his privacy. He also believed that the FAA request was unreasonable because he had timely filed an Aviation Safety Reporting System (ASRS) report about the gear-up incident, which he felt provided him with immunity from the FAA probing.
The refusal didn't sit well with the FAA. As is usual in such cases of refusal, the FAA issued an order suspending all of his airman certificates — not only his flight instructor certificate, but also his pilot and medical certificates. That is certainly one answer to the question of "what happens" after a refusal.
As was his right, the flight instructor appealed the FAA's order to the NTSB. A hearing was held before an NTSB administrative law judge. The flight instructor's arguments didn't sway the judge. The judge sustained the FAA order. The instructor then appealed to the full five-member board, as again was his right. The full board also affirmed the FAA order.
Re: FAR's ?
lowflybye wrote:Take a gander at 14 cfr part 61.51 (i) (iii)
While that regulation does exist, there is also FAR 61.3, below. Notice the lack of the word "reasonable" in the requirement to present your certificate, medical, and photo ID. Apparently, the request only has to be "reasonable" when it comes to your logbook :? :lol:
(l) Inspection of certificate. Each person who holds an airman certificate, medical certificate, authorization, or license required by this part must present it and their photo identification as described in paragraph (a)(2) of this section for inspection upon a request from:
(1) The Administrator;
(2) An authorized representative of the National Transportation Safety Board;
(3) Any Federal, State, or local law enforcement officer; or
(4) An authorized representative of the Transportation Security Administration.
Re: FAR's ?
I think this boils down to is a illegal detainment/arrest by a "Barney Fife" cop. It's important to firmly ask the officer if he is indeed "detaining" you and on what cause. It must be because he has some sort of reasonable suspicion that you broke a law or committed or were in the process of committing and act or crime.
Last summer, I was visiting my parents quiet lakeside community. The neighbor had called the police to report a domestic violence incident by her husband. they both had been drinking. He was not on scene. Before the cops showed, she flagged me down and was visibly shaken, but not injured. I happened to be on scene when the cops arrived. I explained to them that I was just a neighbor and did not want to get involved with the police report or anything related to the incident. The cop then demanded my I.D, even though the lady confirmed I was not involved and just there to help her.
I told the cop that I was not able to produce an I.D. at the time because i was in swim trunks and my house I was living in was across the street. I told the Cop that I was going to leave because my 5 year old son was needing looked after and he was only being watched by some teenagers near the lake.
He told me to go. Upon leaving the #2 young kid cop drives up and gets out. I explained to him the other cop told me i could go and thats what I intended to do. He TOLD me that i was not going anywhere and I was to go sit on the porch, until I could produce I.D.
I kindly replied that I know a little something about Law Enforcement because I was involved in military Law enforcement when I was in the military. I said to him that unless he was intending to "detain" me, i have nothing further to say to him and that I will be on my way. Well, that pissed him off and he later approached me accusing me of impersonating an officer and demanding my I.D.
I just laughed and turned away, told him I declined to cooperate and to have a nice day. The snot nosed kid cop then turned in haste and while stomping off to his patrol car said to me " Hope to see you around town someday".
I guess my point is, that you need to respectfully stand up to un-just authority. Often if you call bullshit on them then they know they cant have any power and that you will not give into being badgered or threatened. It sounds to me as if you need a legal advisor and fast! I would definitely sue this City if you have the financial means to do so. It would engulf me with rage, if I were arrested and thrown in jail and treated like a criminal, without just cause or any crime being committed.
lownslow79 offline
Aircraft: 72' Cessna 150L
Re: FAR's ?
Boy is this thread ever timely! My recent experience has nothing to do with the FAA, but does the authorities that be, and I do fly over the nearby Port all the time, it's a few miles from my strip.
I just drove my crane 4 miles, and of course had to go through the Inkom Port of Entry on I-15. I got the dreaded "brings papers inside" sign, and did so. While waiting several minutes at the counter (no one else there, the scale is automated, but she wanted to make me wait I guess) she checked the paperwork out and then like a dummy I said it had been a long day. "What time did you start " she asked. "6:00 AM, she immediately informed me I was "out of service", (it was 6:10 PM). I told her that she may have misconstrued my comment, as I was referring to burning some brush on my property (and you can SEE my place from the frigging Port) BEFORE running the boom truck for 45 minutes hours later and then driving it 4 miles. She said it didn't matter, work is work, and I was over the numbers for DOT "time in service"! At that point I turned to leave, and wished her a "have a nice day".
It started bugging me though, so after I got home I called the local state trooper barracks, and had a helpful trooper assure me it was meant to be "work for compensation" as in hours of service. I made it clear to him I putzed around the place, then ran the crane for less then an hour, and then, on the way to it's storage lot, had to go through the Port. No problemo he said, you're cool (or words to that effect). I should have quit there, but then I call the Port, ask her name and refer to the incident less then an hour earlier and mention (in as non threatening way as conceivable, "brown nosing") there seemed to be a misunderstanding as to her interpretation of the DOT rule. She wouldn't budge an inch, and I was tempted to tell her that if I WAS "out of service", why the hell did she allow me back on the interstate driving 45,000 lbs of truck! Then, as the trooper recommended I do, I asked when I could talk to her supervisor about her interpretation......
So now, come Monday AM, I have to decide if I walk in the Port with definitive proof of my correctness, or just eat it and let it slide. She's been a Port Puke (MEANT AFFECTIONATELY) for 21 years, is a local like me, and for the life of me I can't see why she had it in for me, and no, she was too old for that "must be that time of the month", thing. You are sexist for even thinking that!
Re: FAR's ?
My old Pappy taught me two rules and a definition to live by:
rule #1. - - The golden rule - - The man with the gold rules.
Rule #2. - - The gunden rule - - The man with the GUN rules over the man with the gold.
Diplomacy: - - The process of saying "Nice doggy, doggy, doggy, while you look for a rock."
Trimtab offline
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
Re: FAR's ?
So what happened that caused the crash? Did the engine sputter or give you some indication that a powere failure was iminant? I'm always curious and hopeful to learn from the experience of others so please share. Also, if I understand correctly from your post you are saying that some cop came and arrested you AFTER the FAA showed up, completed thier investigation and released the plane back to you? I would think the local law enforcement would show up long before an FAA guy.
66skylane offline
Re: FAR's ?
George, you and Jake need to get your ass back to Alaska where airplanes and their useage is a little better understood, I think. We are leaving Baja this Monday, I will be careful when I enter the People's Republic of California. Best wishes and glad you are ok. FF
FloatFlyer offline
Re: FAR's ?
Still don't know for sure what caused the lack of power, am leaning towards bad mechanical fuel pump, and a boost pump that did not have enough volume or pressure to keep the engine running at full throttle. Was a couple hundred feet in the air, 2700' strip, bluff at the end with houses at the bottom, about a mile to a hiway or fields.
Finished with the FAA and NTSB on the phone.
Went downhill after that.
Don't want to say much more on the forum.
Have good criminal Att. Has cost quite a bit, supposed to have a jury trial in Dec. Per my request so I can work this summer and not have to miss work and travel back and forth, the outfit I work for would have to import some one while I'm gone, be a big PITA
Thanks all for the help, Keep it coming using it all.
GT
M6RV6 offline
Re: FAR's ?
FF
I agree should be headed that way by end of the month.
Looks like I will be taking Victors new yellow Pacer up for him.
Have 4 new cylinders on it, should be a good trip to break them in?
Will you and that pretty girl that puts up with you be back to AK this summer?
I guess I won't be planeless this summer, Have a new acquaintance that can't come back thru Canada for an indesrcretion from many years ago, Has a 170B with a 165 Franklin. He wants me to bring it down this fall, should be able to use it this summer.
You know that saying Just say No!
Be careful sometimes that doesn't work!!
GT
M6RV6 offline
Re: FAR's ?
George: If we do make it to AK it will be in the Sitka/Ketchikan area. This year it is the Yukon/NWT turn to visit. Amazing what the Canadians may choose to enforce as a reason to deny entry, sigh. Let me know if you will be flying by our place, plenty of room. FF
FloatFlyer offline
Re: FAR's ?
courierguy wrote:Boy is this thread ever timely! My recent experience has nothing to do with the FAA, but does the authorities that be, and I do fly over the nearby Port all the time, it's a few miles from my strip.
Tom....
Personally I would create a written timeline of events and what she said and what you responded to, Quoting her answers as best you can remember. First thing Monday morning go back to the port of entry and politely ask to see the supervisor. Avoid her at all costs till her boss is running the show. My humble opinion is ..... she might have been having a bad day but that is NO excuse to treat the public, who pays her salary, the way she ragged on you. It is a good bet she has just enough authority to play god and have all the 'underlings' dance to her wishes, and she probably does this daily. It is up to you to break this habit she has..... Idaho is a few hundred million in the red and her job with all its benefits will quickly be refilled by a decent human being and she can add her name to the unemployed roles. She needs to go back under her bridge to play "troll" by herself. At the very least she owes you a sincere apology.... IMHO.
Ben
Stol offline
20 postsPage 1 of 1
