Backcountry Pilot • Favorite Spark Plugs for O290-D
5 postsPage 1 of 1
Just wanted to get some input on favorite spark plugs for Lycoming O290-D operators. I'm running REM 40E and seem to get some fouling. What have you had the best luck with?
Kitfox5 offline
Aircraft: Kitfox5 Lycoming O290 Powered
Vans RV6
C180K
Re: Favorite Spark Plugs for O290-D
I'm running REM40E champ's in my O-320-E2A. They work fine, as do Unison's (now Tempest).
Are you running avgas? Try the ethanol-free mogas over at lebanon state airport-- not sure if it's 87 or 92 octane, but even 87 oughta be OK with a 290D, although a D2 might need 92.
If carbon fouling, try leaning more. If oil fouling, you've got bigger problems.
I'm running REM38E's in my O-320. They aren't the right ones by the book, and I do have a fair amount of fouling, especially when doing aerobatics. I have 40s on order and plan to change them asap. I'd stay with the 40s, and like hotrod says, try leaning more or mixing some E-0 fuel in it.
Sent from my Galaxy Nexus using Tapatalk 2
I had an O-290d2 in a Piper J-5 that would foul plugs, switched to fine wire plugs and the problem went away. Cant remember the number but maybe the fine wire version of the one you are using.
westerncolorado offline
I originally ran an old set of fine wire, and I think they worked much better, thats pretty much why I'm asking. But they are so dam expensive.
Kitfox5 offline
Vans RV6
C180K
5 postsPage 1 of 1
