I'm curious...
On a push pull, are the props generally the same (or can they be different?) because of the turbulence, air velocity differential, and other factors? I figure you really can't have too big of a torque difference front vs rear because that would create some roll wouldn't it? I am also not sure about harmonics and other vibration factors relating to the use of different props, rpm settings, and for that matter even different engines, for inline twin configurations.
Also the video and article in the link note that one of the 914 engines is carb, the other fuel injected. Is that for redundancy ie, the carb is a tad simpler with no complex injectors and related electronics, whereas injection does not suffer from carb icing issues? Anyone know?
I've seen
Cessna C-337 Skymasters flying above me, but have never actually approached one on the ground to have a closer look. Sort of a rare bird, at least around here.
You know, the thing about this website
backcountrypilot.org, the more you read, the more you begin to realize how much more there is to know about almost everything. Humbling actually.
That
Double Ender is some kind of cool plane ! In a weird sort of way it somehow also reminds me of the
Oscar Meyer Wiener Mobile. Not sure why?
