federal 3000 ski oil
Hello Folks,
just wondering if anyone on here is running the federal 3000 wheel skis and if so what oil are you running in them. whatever is in mine looks and smells a lot like ATF which makes a lot of sense as I run that in a lot of my hydraulic equipment, but I doubt anything aviation uses ATF!!
thanks
Steelroamer offline
119
- FindMeSpot URL: https://maps.findmespot.com/s/D8VB
- Aircraft: maule M6 on Floats
StillLearning offline
464
- Aircraft: Cessna 180 Skywagon 1953
StillLearning wrote:5606?
The ATF of aviation.
IIRC, while both 5606 and ATF are mineral based, ATF could have some additional lubricants required by a hydrostatic transmission. 5606 is also red/pink.
A can of it is cheap and can be ordered from Spruce or the like.
2991
- Aircraft: None
5606 flows much more readily in cold temperatures. It does make a significant difference in winter hydraulic applications.
marcusofcotton offline
259
I use 5606 in skis and brakes. Buy a quart and use a old school squirt can with flex tip for toping off.
DENNY
DENNY offline
791
DENNY
