Backcountry Pilot • Federal AWB 2500 on a Scout ??
4 postsPage 1 of 1
Looking for advice from those that know.
Will these Federals fit on a Scout??
Is there an STC or a Type Certificate (CDN) for the AWB 2500s on a Scout??
Thanks in advance.
Kevin
BellancaScout offline
Re: Federal AWB 2500 on a Scout ??
Edit. Didn't read that right.
BellancaScout wrote:Looking for advice from those that know.
Thanks in advance.
Kevin
Never seen or heard of AWBs on a Scout. They are heavy and not that great in deep snow. You'd have to have ski axles specific to the Scout gear, as well....these skis attach to ski axles that bolt on to the gear, opposite the main gear axles. That requires ski axles that match the bolt pattern on the Scout axles, plus the longer axle bolts.
I'd call Atlee Dodge's shop in Anchorage, they may be able to tell you if there's an stc out there somewhere.
All registered FAA STCs for your Scout are listed in this database...
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgSTC.nsf/MainFrame?OpenFrameSet
Every few years I look here to see who has mods for my airplane.
4 postsPage 1 of 1
