Feedback
I am getting noise feedback thru both headsets when I turn my intercom system on. The feedback does not start until I reach 1700 rpm on the engine and increases intensity as I increase engine rpm. I have played with all the setting in the radio and I have not been able to resolve the issue. If I operate the radio with out the intercom being turned on it works just fine. I have tried different headsets with the same problem occuring. What could be the issue?
redlinemike offline
24
1970 Citabria GCBC
1983-1984 Sikorsky Blackhawk UH-60A
Sat Oct 06, 2007 12:37 pm
Sounds like alternator whine getting into an unshieled wire in the intercom?
a64pilot offline
1398
If there is any more information I can get for you to try and isolate this problem let me know and I will try to get it. Meanwhile, I will try what you have suggested so far.
redlinemike offline
24
1970 Citabria GCBC
Is it a whine that increases in pitch with RPM? Does it change if you turn the alternatior off?
a64pilot offline
1398
It is not so much a whine, but more like the sound if you hold a cell phone next to a speaker during a call. It increases directly with RPM, e.g. 1700rpm produces slightly audible noise and full power produces maximum intensity sound.
redlinemike offline
24
1970 Citabria GCBC
I think I fixed it. I examined the wiring and found a wire end that was half covered with electrical tape and it had become a little exposed and might have been contacting the headphone plug. I recovered a few loose wires and I did not have time for a run up and check but hopefully tomorrow I will. Thanks for the info.
redlinemike offline
24
1970 Citabria GCBC
