The picture of the Vertical Stabilizer is there to show my support of the drought situation in the central valley with a brown V.
hope you enjoy...
Mike
aktahoe1 wrote:Steve said between 10-12lbs
Battson wrote:You could surely make it work Tadpole, it's a homebuilt after all!
182dude wrote:I believe the footprint of the 520 is very similar to the 470, but not sure...i have heard that the 520 and 550 are identical as the 550 is a stroked 520...the engine really to me doesnt look to be any bigger or wider but i have no measurements of before and after...no mods to the cowl and the baffles are the same kit as the 470 so assuming they are very close.
Mike
180Marty wrote:Nice looking installation. How many blades for it to start since you don't have a primer?
Tadpole wrote:How much more did your 470-50 weight compared to the 470 you had before? Does it actually grow in size under the cowl as well? I'm wondering if a 470-50 would work on a Bearhawk
182dude wrote:It has the primer like my 470 had...in 1974 or 1975 they changed it to inject fuel into the cylinder...mine is a 1973 model i believe it squirts it up into the intake manifold...that being said i think that system sucks and is a piece of Sh!t and just leaks gas out of my primer knob into the cockpit, so i crank it 2-3blades go a quick very quick pump on the throttle and it comes online. If i do nothing at all but crank usually 6-7 blades, it comes on quicker with a quick pump and it runs very smoov doing it that way!
