Backcountry Pilot • Field approval 337 for my 182 fork and tires
11 postsPage 1 of 1
Hey guys I am finishing up the annual on my new to me 1957 182. I have installed a heavy duty nose fork and 6.00x6 tire and in process installing 8.00x6 mains. I could use any advice about the field approval process that anyone could offer. Or if anyone has had a successful field approval or 337 that they could share with me it would be greatly appreciated. Thanks
Bill
Wildblue182 offline
Aircraft: 182a
Re: Field approval 337 for my 182 fork and tires
My first piece of advice is don't install any parts on your airplane that require a field approval until you have the field approval, you may be grounded for months waiting for it. Oh yes, also it's kinda illegal.
Second, make sure there are no STCs available for what you're trying to do or they won't sign off on it. Feds won't approve a field approval for something that could be approved by available STC.
Third is do what you're doing, try and find someone who's done what you're trying to do. Preferably an A&P that works cheap! [emoji3] Copies of previously approved installations are great but not necessarily a slam dunk. Also DERs are a great resource.
Halestorm offline
Aircraft: C-182E Pponk
Thanks Hale. So far I am operating as my own a&p. I just don't have a lot of paperwork experience on such matters. I have been out of aviation for 13 years until this little 182 showed up in my life. I'm just trying to spruce her up a little. The more research I do I am starting to consider this just a minor alteration with perhaps no need for field approval. There is not really a big change in weight and by 1962 this was optional equipment. I don't feel as if im reinventing the wheel with this upgrade. Any opinions on the idea of this as a minor alteration?
Wildblue182 offline
Aircraft: 182a
Since no one has jumped in with a firm answer yet, I will throw in my 2 cents. Not sure what you meant by hd fork, but if you you have a 206hd/310 nose wheel fork you are using, I believe its just a minor alteration installing optional equipment. The large fork should be listed in the TCDS as an option. I'm thinking I've read it and also it specified approved tires as well. Its been a while since I last read it. #-o :roll:
RockHopper offline
Rock, seems it wasn't an option until 1962. And btw way it is a cessna 310 fork. It is looking like I will need a 337 field approval.
Wildblue182 offline
Aircraft: 182a
I owned a 56 182 for a short time with the setup you are describing. It was on it when I bought it and it paperwork to go along with it. I believe was a field approval and I definitely remember seeing a letter from Cessna approving/backing up the setup. This was N5351B if you want to pay the $10 and get a copy of the cd from the FAA.
I put the same setup on my current 66 182J and it was an easy logbook entry since it was an option from the factory to do it.
Hope this helps.
BlindPilot offline
Aircraft: 1966 Cessna 182J
I have a heavy duty nose fork and 8.5x6's on my 172 i can send you photo copies of the 337's if it'll help?
88Echo offline
Aircraft: 1959 Cessna 172
Wildblue182 wrote:Thanks Hale. So far I am operating as my own a&p. I just don't have a lot of paperwork experience on such matters. I have been out of aviation for 13 years until this little 182 showed up in my life. I'm just trying to spruce her up a little. The more research I do I am starting to consider this just a minor alteration with perhaps no need for field approval. There is not really a big change in weight and by 1962 this was optional equipment. I don't feel as if im reinventing the wheel with this upgrade. Any opinions on the idea of this as a minor alteration?
Where are you located. I have done two of them.
Tim I am located at grosse ile Michigan 2G5
88echo, that qould be great if you could send me some pics of the 337
Blindpilot thanks for the info, I may get the cd
Thanks to all you guys
Bill
734-558-8072
[email protected]
Wildblue182 offline
Aircraft: 182a
I know zip about the nose fork issue, but as the owner of a much modified airplane that seems not to be on the AMLs of most after market thingies, I'm familiar with the delays in getting field approvals--and it's much worse now than it was 10 years ago, at least in the Denver FSDO area. It used to be that my IA would make a request, and 2-3 weeks later, we'd have the paper work. Now it's more like 2-3 months if we're lucky. My latest improvement 337 was started in late August last year, and it took until mid January to get the FAA's approval, and the item was ordered after that (echo: don't make changes until the 337 has been approved). Then the manufacturer is running behind, so at least as of this morning, we still don't have it.
Sent you the 337 in an email yesterday. Hope it helps.
88Echo offline
11 postsPage 1 of 1
Users browsing this forum: No registered users and 26 guests
