Field approval help on prop for Continental IO-360
I have a Maule M-5 210 and that currently has a 74 in prop on that i would like to change. From the research i have done probably a C-201 with 80-84 inch blades. I am not set on any one prop and would like suggestions. If you have done this or something similar i would like to visit and possibly obtain a copy of your 337 to make things easier.
My engine is a: continental model IO360 d33
My current prop is a: McCauley d2a34c67-no series:710082 Blade #76c-2
Thanks
airfarmer offline
16
- Aircraft: Maule m-7-235
Maule m-5-210
Comanche 250
Wed Apr 15, 2015 12:29 am
Farmer,
I think the c203 is the most common long prop replacement. Check out maulepilots.org. There are a number of threads on props for the io-360 e.g.:
http://maulepilots.org/forums/viewtopic.php?t=1711&highlight=io360Jim, aero101, over at the Muale site has done a number of field approvals, and is always full of good information.
Chet
chetharris offline
57
Thank you ill have to check that out.
airfarmer offline
16
Maule m-5-210
Comanche 250
I've been digging around looking at prop options for a TCM IO360. The biggest prop I've been able to find that has been vibration tested is the 82" C203. I was hoping for a 84" but no luck as of yet. The nice thing about the 82" C203 is they are used on the Cessna 182 so finding a good used one should be pretty easy.
If you find something bigger please share.
3386
I guess it was meant to be because in our local A&P just just pulled off a c203 80 inch off a 182 with about 400 hrs. Jim up at North Star Aero was a big help. Now i will see how long it takes to get the field approval. Thanks a bunch ill hopefully be letting y'all know soon how much it helped.
Thanks
Justin
airfarmer offline
16
Maule m-5-210
Comanche 250
FWIW the R172K uses a 80" C203 on the TCM IO-360. So does the XP mods STC for that engine on the C170.
c170pete offline
294
I've got an 82" C203 on my 180, down to minimums at about 80.5". It'd be perfect for cutting down & cleaning up at 80". If & when I find myself an 88" seaplane prop, it will be available very reasonably.
10534
thanks 170pete the more info on that engine will just make it easier.
Hotrod180 let me know if you decide to sell it. The guy that i thought i had one from can't decide if he wants to sell.
airfarmer offline
16
Maule m-5-210
Comanche 250
i have a 76" 209 on my M4.. IO360 A ... been lusting for a 203 80 inch for years.. but the monstrous price has kept me from better climb and performance...and yes... check with aero101..
iceman offline
2026
Sat Apr 18, 2015 11:38 pm
I'm getting pretty excited getting a new prop is finally becoming a reality. Aero101 was a huge help sending me 337s that he had done. I found a c203 82 inch used prop for $3000 with 500hrs. Is that cheap or expensive or about right?
airfarmer offline
16
Maule m-5-210
Comanche 250
Sun Apr 19, 2015 10:15 pm
That price is fair n is bout what I paid for a similar 82" McCauley from another BCPr, hope it works well for u! Don't forget to holler when ur down flyin my way [emoji12]
Skalywag offline
783
Do a search on barnstormers: propeller, then MacCauley.
Maybe not C203's, but Preferred Airparts seems to have lots of McCauley props in OH'd condition for sale for between $4 & 5 K.
10534
hotrod180 wrote:I've got an 82" C203 on my 180, down to minimums at about 80.5". It'd be perfect for cutting down & cleaning up at 80". If & when I find myself an 88" seaplane prop, it will be available very reasonably.
It's up for sale, check the marketplace forum for my FS post.
Airfarmer & Iceman, check it out.
10534
